Smittybilt Rear TJ Tube Fenders? - JeepForum.com
post #1 of 18 Old 01-31-2011, 08:01 PM Thread Starter
ccbruin
Has anyone put these flares on their YJ? I was thinking if I am going to get them, why not go with the TJ ones right? Anyone have the TJ's on a YJ?
http://www.quadratec.com/products/12057_250X_PG.htm
ccbruin is offline
post #2 of 18 Old 01-31-2011, 08:28 PM
timatoe
timatoe's Avatar
Don't see why it wouldn't work. I know the corners are the same, cause I have Poison Spyder TJ corners on mine. Just an FYI though the fuel filler will require you to cut into the wheel well in the actual TJ position. I just made a little sheet metal cover to go over it and covered it in herculiner.
timatoe is offline
post #3 of 18 Old 01-31-2011, 08:32 PM Thread Starter
ccbruin
^^^ I am talking about the tube fender flares, not the corner gaurds
ccbruin is offline
post #4 of 18 Old 01-31-2011, 10:09 PM
autoboy454
the Smittybilt TJ and YJ rear tube fenders are the same product, the only difference is the instructions that come with it. Should open up the rear wheelwells some, just like running rear TJ plastic flares.
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline
post #5 of 18 Old 01-31-2011, 11:06 PM
timatoe
timatoe's Avatar
Yeh, I gathered that by the original question. I just didn't look at the price and didn't realize the fender was separate from the rest of it, I thought it was all one piece. If you're bolting those to the tub, it'll be no different than using any other TJ flare.
timatoe is offline
post #6 of 18 Old 02-01-2011, 06:38 AM
'92 vegas YJ
I'm going to try to use some tj full corner guards with flare.....
'92 vegas YJ is offline
post #7 of 18 Old 02-01-2011, 04:19 PM
brianOU
Are you sure on this? my new smitty YJ rear tube flares are sitting in my garage and they line up exactly and do not enlarge the wheel well at all.
brianOU is offline
post #8 of 18 Old 02-01-2011, 05:47 PM
autoboy454
I do not have the email saved anymore, but when I ordered mine, I contacted Smittybilt directly to make sure that the YJ flare part # and the TJ part # for the rear flares were in fact the same flare. I was told by them that the only difference is the installation instructions...
post #9 of 18 Old 02-01-2011, 06:35 PM Thread Starter
ccbruin
On quadrtec the Yj and Tj ones have different part numbers
ccbruin is offline
post #10 of 18 Old 02-01-2011, 06:51 PM
brianOU
They have to be different.. Because if u put the yj flares on a Tj then it would make the wheel well smaller.
brianOU is offline
post #11 of 18 Old 02-01-2011, 07:06 PM
autoboy454
I have a set sitting at home (i'm up at college right now but going home this weekend.) I will get pictures of them and post them up to verify. The only reason I bought mine was because I liked the tube flare look and wanted a larger wheelwell for my 33's
post #12 of 18 Old 02-01-2011, 07:35 PM
'92 vegas YJ
i completely agree. it wouldnt make sense for them to be the same size...
post #13 of 18 Old 02-01-2011, 07:39 PM
brianOU
If you have the Tj flares, take some measurements and I have the yj flares, I will take measurements as well.
brianOU is offline
post #14 of 18 Old 02-06-2011, 01:31 PM
autoboy454
I ordered the YJ rear flare kit, and took some measurements of them today. measured from the shorter side (rear) across the bottom to the longer side (front of flare) and it came up 33-3/4". From that horizontal line I measured up to the bottom of the mounting flange, and got 13". Just eyeballing the Smittybilt flare to my brothers stock 89 YJ rear flares, it looks as though the Smittybilt YJ flares are a good inch or two wider and taller than stock, allowing for more room. IDK if it is the same measurement as the TJ flares, but I would have to assume that because of the larger size for YJ's that it is close to a stock TJ flare.
post #15 of 18 Old 04-16-2011, 11:19 PM
CMFast
I bought the TJ flares for my YJ, they are bigger.
CMFast is offline
Smittybilt Rear Tube Fenders?? hallway94yj YJ Wrangler Technical Forum 20 01-02-2014 12:33 PM
Smittybilt XRC Tube Fenders $256 Jesse_87 YJ Wrangler Technical Forum 2 11-13-2012 01:08 PM
Smittybilt rear tube fenders for yj. Where? Jeeper_YJ YJ Wrangler Technical Forum 78 03-02-2011 02:39 AM
Smittybilt tube fenders for rear detroitmurph TJ Wrangler Technical Forum 4 04-16-2009 03:13 PM
Smittybilt (SRC) Tube Fenders...$200!! JJs99TJ TJ Wrangler Technical Forum 241 10-28-2006 09:43 AM
