smelly exhaust - JeepForum.com
post #1 of 2 Old 06-22-2001, 11:15 AM Thread Starter
whatarush
smelly exhaust
I drive a 89' Jeep Wrangler with a 258. I have replaced the carb. with a holly to stop the common problem with the carter. I have also replaced my muffler with a Gibson to help a bit with performance (the old muffler was shot as well).
Here is my issue. The f'in thing stinks. I take off the top and the smell on the fumes is horrible. I don't know if this is a common problem with Jeeps, but I feel like it is going to knock me out the smell gets so bad. The 258's in 89, maybe other years as well, have some crazy emissions set up with hoses running all over the place. When I put on the new carb I had to drill some holds in the top to run in the back flow exhaust. If you follow the hoses to their origin one will find a one way valve that is involved with the exhaust.
Anyway, just wanted to throw in as many detail as I could to see if anyone had the slightest idea as to why my Jeep smells so bad. By the way I take two showers a day and use deoderant, so it aint me.
Thanks all.
whatarush is offline
post #2 of 2 Old 06-23-2001, 03:43 AM
JeepinMan22
hello.....well being jeeps have the areodynamics of a brick, the jeep creates sort of a vacume (sp?)...i have the same probablem and this is what i was told....i also noticed the smell after changing from a new exhaust system...exits straight out the back instead of curved down.......this is only what i think though??
good luck
mike
keep is on all fours
JeepinMan22 is offline
Hot smelly YJ rhinoyj YJ Wrangler Technical Forum 5 07-02-2009 05:06 PM
Smelly smoke coming out of passanger side dash superslayer TJ Wrangler Technical Forum 4 03-06-2009 05:52 AM
Smelly seats. JonnyOneNut TJ Wrangler Technical Forum 7 01-15-2008 04:15 PM
smelly yj toates89 YJ Wrangler Technical Forum 18 09-05-2006 09:14 PM
smelly clutch dex94 YJ Wrangler Technical Forum 3 04-20-2006 08:33 PM
