smelling blower motor? - JeepForum.com
post #1 of 6 Old 08-09-2013, 09:08 AM Thread Starter
Dragonwitch
Every time I use my heater and the fan is on High, after a few minutes I get a strange smell. I was told it was probably the blower motor getting ready to go. What is the easiest way to get to it? Is it under the dash or will I have to lay the windshield down to open it all the way. I need to fix this before winter. We recently fixed a leak in the windshield which was probably the cause of it going bad.
try everything at least once before you form an opinion
Dragonwitch is offline
post #2 of 6 Old 08-09-2013, 09:21 AM
jbrown73
Not sure about the 95 YJ installation, but the blower motor on my 89 YJ is attached to the firewall through the engine compartment under the battery tray. I know the newer blower motors are larger than the stock motors (again, at least for the later models) and I had to cut the hole in the firewall a little large to accomodate which required having to take out the air box under the dash.....gave me an excuse to clean it all up and replace the seals.
Someone with a newer YJ might need to chime in.......
"The Constitution is not an instrument for the government to restrain the people, it is an instrument for the people to restrain the government....." - Patrick Henry
Originally Posted by Rproject View Post
The only thing I can say is to close your eyes. Seriously. If you close your eyes and pay attention to your finger tips, you'll be able to feel the nuts better and manipulate them easier.
jbrown73 is offline
post #3 of 6 Old 08-09-2013, 09:27 AM
GrantYJ
On my'92 (which should be like yours), I had to pull the heater box out. The fan motor was attached to the heater box and the motor sticks through the firewall.
This is not a fun job...
Do yourself a favor and put in a new heater core while you've got it apart.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #4 of 6 Old 08-09-2013, 09:45 AM Thread Starter
Dragonwitch
OUCH...well if I want heat this winter I better get to it. This sounds like its gonna be a project...uhhgg
Thank you for the input.
post #5 of 6 Old 08-09-2013, 10:08 AM
Firefyter-Emt
This is as easy as it gets for pulling heater boxes. There are just four bolts on the firewall and the cables to disconnect. As stated, replace both the core and blower motor at the same time. I would also take the time to wash out the inside of the box and the foam flap doors (the flap doors are best removed and washed by hand with some dish soap). I also replaced the fan resistor in the upper plenum when I did mine... They are cheap enough to replace while you are doing everything else. That part is what gives you the blower speeds.
Doing all this will give you some nice warm and clean heat all winter.
Firefyter-Emt is offline
post #6 of 6 Old 08-12-2013, 09:45 AM Thread Starter
Dragonwitch
Awesome..thanks for all the help
