Smell Diff fluid after wheel Cylinder change - JeepForum.com
post #1 of 4 Old 11-04-2012, 04:47 PM Thread Starter
Plyj
Hi All -
1990 modified YJ (auto trans)...
This weekend I noticed fluid on the inside rear (drivers side) tire. Checked the brake fluid and (sure enough) rear reservoir was very low. Long story but I ended up doing both rear wheel cylinders and brake lines. Along the way, I cut out the rear track bar since the bracket had rusted through and it was just flopping around. Yes... a long weekend.
Anyway, took it for a wonderful, long drive and it ran just great... I LOVE JEEPS!!!
When I got it home, I smelled that high content lithium smell of Differential fluid (actually, I smelled it before but thought it might be the brake fluid combined with brake dust, etc). So... I'm thinkin' rear axle seal or something like that. My question is... can I just ignore this until next spring? It's starting to get cold here (Massachusetts) and I don't really want to get under the beast when it's 20 degrees. I drive it only on weekends and, then, only to the dump, Home Depot, and the Beach (about 5 miles round trip).
Any advice would be great... thanks in advance.
Plyj is offline
post #2 of 4 Old 11-04-2012, 06:26 PM
jokerchief462
Sure until you see a puddle I wouln't get too excited but it does require attention. It depends on how much is leaking and how much you drive.
jokerchief462 is offline
post #3 of 4 Old 11-04-2012, 06:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just keep checking on the level every other trip or so. You have ten dipsticks so you should use them. Eleven if you're creative
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 11-05-2012, 06:12 AM Thread Starter
Plyj
Great !
No puddles yet, just a few lines radiating on inside tire.
Thanks
Plyj is offline
brakes , differential fluid
