-   -   Smell Diff fluid after wheel Cylinder change (http://www.jeepforum.com/forum/f12/smell-diff-fluid-after-wheel-cylinder-change-1434730/)
Plyj 11-04-2012 05:47 PM
Hi All -
1990 modified YJ (auto trans)...
This weekend I noticed fluid on the inside rear (drivers side) tire. Checked the brake fluid and (sure enough) rear reservoir was very low. Long story but I ended up doing both rear wheel cylinders and brake lines. Along the way, I cut out the rear track bar since the bracket had rusted through and it was just flopping around. Yes... a long weekend.
Anyway, took it for a wonderful, long drive and it ran just great... I LOVE JEEPS!!!
When I got it home, I smelled that high content lithium smell of Differential fluid (actually, I smelled it before but thought it might be the brake fluid combined with brake dust, etc). So... I'm thinkin' rear axle seal or something like that. My question is... can I just ignore this until next spring? It's starting to get cold here (Massachusetts) and I don't really want to get under the beast when it's 20 degrees. I drive it only on weekends and, then, only to the dump, Home Depot, and the Beach (about 5 miles round trip).
Any advice would be great... thanks in advance.
jokerchief462 11-04-2012 07:26 PM
Sure until you see a puddle I wouln't get too excited but it does require attention. It depends on how much is leaking and how much you drive.
Anticanman 11-04-2012 07:45 PM
Just keep checking on the level every other trip or so. You have ten dipsticks so you should use them. Eleven if you're creative
Plyj 11-05-2012 07:12 AM
Great !
No puddles yet, just a few lines radiating on inside tire.
Thanks
The time now is 06:24 PM.
