smallest idle jet possible the best? - JeepForum.com
post #1 of 2 Old 05-22-2012, 12:58 PM Thread Starter
bluedaffy
I've read that using the smallest idle jet possible with the mixture screw within the spec range is the best. can somebody please confirm or denounce this?
I have a weber 32/36 and there is zero vacuum and the spark advance port during idle which is the goal when setting curb idle, but my jeep allows an idle with a 60 primary idle jet. Is this okay? It seems quite a bit different than the stock 75 bu the idle is smoother and a lot less stinky.
Thanks, bluedaffy
bluedaffy is offline
post #2 of 2 Old 05-22-2012, 04:16 PM Thread Starter
bluedaffy
bump
idle
The Worlds Smallest Hampster Leans93 YJ Wrangler Technical Forum 10 08-11-2010 02:27 AM
What is the smallest rim size that will fit the JK? xjtrailrider JK Wrangler Technical Forum 4 01-26-2008 06:36 PM
Smallest cheapest lift to fit 31s contestant#1 YJ Wrangler Technical Forum 18 12-29-2007 05:44 PM
Smallest backspacing available... charlotte TJ Wrangler Technical Forum 2 04-05-2005 01:30 PM
smallest tire and rim for a TJ? grimholtz TJ Wrangler Technical Forum 17 11-12-2004 09:10 AM
