small problems after lift install - JeepForum.com
post #1 of 2 Old 04-07-2007, 07:13 PM Thread Starter
zoomin0074
After installing the blackmountain 3.5" lift and 32's I have to push the shifter really hard and hold it in the park position to get the key out of the ignition. Also while engine is running in park or in drive with the brake on I have a engine vibration which wasnt there before the lift & transfer case drop. Any ideas on how to fix these issues?
94 4.0L Auto
SOA Lift on 35's
Red Jeep club #435
zoomin0074 is offline
post #2 of 2 Old 04-08-2007, 02:14 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
I'm assuming your shifter is on the column...
With the t-case drop you've changed the linkage geometry. Crawl up under the rig and add about 1/2 of length (adjustable) to where the linkage meets the trans shifter lever.
As for the vibes, make sure your valve cover is not hitting your firewall (common on t-case drops). If it is loosen the 2 bolts holding the trans to the skid, and using a bottle jack push the trans and engine forward about an inch. Then re-tighten trans bolts.
If not hitting the firewall, Re-torque your trans bolts and outrigger assy on the skid, might be just someting you overlooked.
- Ernie
Richmond88yj is offline
Lift Install Problems.... Unlimited04 TJ Wrangler Technical Forum 22 04-20-2010 05:43 PM
lift kit install problems... jmkeo74 TJ Wrangler Technical Forum 6 02-23-2008 03:00 PM
Problems with lift install No Fear Jeep TJ Wrangler Technical Forum 3 06-16-2007 02:34 PM
More Problems with Lift Install rjkjoe TJ Wrangler Technical Forum 11 09-25-2005 11:13 AM
several problems since my re 4.5 lift install incubus2012 TJ Wrangler Technical Forum 6 05-25-2005 11:06 AM
