Small main shaft leak....anyone else? - JeepForum.com
post #1 of 9 Old 11-15-2001, 07:22 AM Thread Starter
Big92Jeep
Main rear shaft out of transfer case throwing a little (red ATF). Of course the rear drive shaft throws it up under the jeep. Only about a dime size spot on ground when it sits overnight. Keep fluids topped off so I am not to concerned. Wondering if anyone else has this problem or has had to replace the seal???
As far as I am concerned it's just marking it's teritory. I also have a theory that if fluid can get out then water can get in.
Thanks in advance for any info.
~Rýck
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #2 of 9 Old 11-15-2001, 07:43 AM
Newfie
Yeah, I have a small weep of it as well. Concerns me though, as it probably means the shaft is starting to go (or gone) out of true and will start to chew up the rest of the components. I really need to install an SYE...
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
post #3 of 9 Old 11-15-2001, 08:54 AM
mikeyjph
I had the same problem after I put a suspension lift on and the cheap t-case drop kit, a new seal solved the problem
mikeyjph is offline
post #4 of 9 Old 11-15-2001, 10:23 AM
evilpsych
evilpsych's Avatar
yeah a new seal will fixt that.. think they're fairly cheap..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #5 of 9 Old 11-18-2001, 06:35 PM
bighair
yeah, I have a 93 yj and the same .. the seal leaks a little. I'm going to change it on my next day of.. Tuesday.
It doesn't seem like a big Job. I alread replaced the ujoint there and noticed the leak.
All you have to do is take the clip that holds the ujoint and dive shaft off slide the driveshaft out, and pop the seal out. dont forget to try and drain some of the fluid first cause you know it'll leak..
I have heard taht you need a puller tool to take the seal off but if it's already damaged and you are replacing it.. you should be able to use a screw driver to pop it out..
I replaced the output shaft seal on a Nissan myself and it only cost around 8$ for the seal. so the Jeeps seal shouldn't be much more.
I'll let you know how it went..
theres my 2 cents worth.. hehe
Team Mod Squad
We are here to help YOU!
bighair is offline
post #6 of 9 Old 11-18-2001, 06:37 PM
bighair
Oh I almost forgot.. with your 4" lift, you must have a SYE?? right?? I don't ahve a lift yet, but I'm sure you should have an SYE if you have a lift .. or some kind of mod to replace it..
P.S let me know if I'm right or not??
Team Mod Squad
bighair is offline
post #7 of 9 Old 11-19-2001, 08:09 PM
powjunkie
I have a 4" lift with a SYE. However, I know several people with a 4" that are running fine without it (on and offroad). I don't really understand how different Jeeps react so differently to being lifted. Mine needed the SYE, but yours may not. It's something I would prepare for, so you're ready to do after lifting if necessary.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #8 of 9 Old 11-20-2001, 07:11 AM
cobra54
I replaced the seal last year for the same thing you guys are reporting. It fixed it for a period of time but it's beginning to "weep" again, but not enough to leave any on the driveway. I noticed that the shaft itself has a slight groove in it where the seal rides - probably from having grit trapped in there over the years and it actually abraded the shaft. If I have to change it again in the future, I'll probably replace the drive shaft with a double cardan if I can find one.
93 Red YJ 2.5L
94 Red F-150 X Cab 5.0L
01 Black Cobra 4.6L DOHC
02 ZX3 Focus 2.0L DOHC
cobra54 is offline
post #9 of 9 Old 11-20-2001, 05:08 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
That seal is a normal thing to replace .. I do it every 2 years or so .. easy as pie to replace .. use a flat-blade screwdriver to pry it out .. and a small hammer to pound the new one in ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Small lift & SYE; do you really need a CV shaft? armyRN TJ Wrangler Technical Forum 17 06-11-2009 06:00 PM
JB S.Y.E. kit for NP231j main shaft too large? idaholtby YJ Wrangler Technical Forum 3 04-28-2008 03:17 PM
small oil leak kercher YJ Wrangler Technical Forum 1 04-09-2007 07:28 PM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 12:46 PM
99 main shaft 95YJnh YJ Wrangler Technical Forum 7 09-16-2005 09:14 AM
