Small Clutch noise - JeepForum.com
post #1 of 6 Old 06-28-2001, 11:58 AM Thread Starter
damonejeep
Small Clutch noise
For the past two - three weeks, I have had a new noise appear when I start out in first gear and let the clutch out. It usually occurs when the jeep has sat for a few hours or over night. The noise sounds similar to a creaking door. I took it to a local shop and they said it was the clutch burning off the rust?
Is this correct or is my cllutch about to fail. There is no slipping of the gears, and everyting else runs and sounds normal.
Any advice or suggestions would be appreiciated.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #2 of 6 Old 07-02-2001, 02:30 AM
bigjeep39
bigjeep39's Avatar
Well, this is very cheezy but it was a creaking door noise for ME but it turned out to be the rubber pedal pad was ripped and it would go up and down on the actual pedal making squeeking noises. I don't know if thats whats wrong but humor me and give it a try.
1998 TJ
Slow steady project.
bigjeep39 is offline
post #3 of 6 Old 07-02-2001, 01:43 PM Thread Starter
damonejeep
I looked at the pedal and it is not a rip. The sound is alot louder than a piece of rubber rubbing. And the noise comes from the middle of the truck, around where the clutch is located.
Andrew
post #4 of 6 Old 07-02-2001, 02:32 PM
bigjeep39
bigjeep39's Avatar
Oh, ok, could it be a bad throw out bearing, possibly- either that or it could be the whole rust burning off, but if it was a bad clutch wouldn't their be clutch slippage.
1998 TJ
post #5 of 6 Old 07-03-2001, 09:58 AM Thread Starter
damonejeep
Cool. If it is a throw out bearing, will this cuase the clutch to fail soon, and is this a easily fixable problem?
Thanks for the advice.
Andrew
post #6 of 6 Old 07-03-2001, 11:16 AM
bigjeep39
bigjeep39's Avatar
Actually from here on out im not too sure i can help you, i mean people do fix them all the time, just check out your Jeep Bible, take care and good luck.
1998 TJ
clutch noise-clutch plates rubbing? Sound like rubbing your palms together anderson1791 TJ Wrangler Technical Forum 14 11-30-2009 01:44 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 08:55 PM
Air conditioner issues and small clutch issue BRC223 TJ Wrangler Technical Forum 3 09-07-2009 01:11 PM
Thumping rattle noise under small load Photog2000 TJ Wrangler Technical Forum 2 07-08-2009 08:34 PM
New clutch noise finnsean YJ Wrangler Technical Forum 2 02-28-2008 11:05 PM
