Sluggish accelleration 94 YJ - JeepForum.com
post #1 of 4 Old 01-26-2002, 06:51 PM Thread Starter
WranglerYJ94
I've got a 94 YJ manual 5spd transmission, owner before me blew the original engine and replaced it with a 2.0 I believe. When im stoppped at red lights, i put her in 1st gear and it feels like im dragging a load behind me, like im pulling a trailer or something heavy, then once the RPM's hit about 3000-3200 you can feel the power kick in and it raeally hauls *** then. but under 3000 rpms i have no power whatsoever. i tried the fuel injecter cleaners that u put in the gas tank with no help. anyone got any ideas what i might do to gimme some MORE POWER!?
THanks,
John
Charlotte NC
'94 YJ
2" BDS
31s
Flowmaster exhaust
Lights
Lotsa 'stuff'
WranglerYJ94 is offline
post #2 of 4 Old 01-26-2002, 07:24 PM
Brendan
If you have a 2.0 Liter engine that really hauls *** at about 3000 RPM is sounds like you have a turbocharger. that isn't definate, but if you the power surges at a certain RPM, then I would definately check your exhaust manifold to see if there is a turbo there, with a pipe leading either to an intercooler (a radiator type thing in the front of the engine bay) or straight to the intake manifold. Either way, if you want more acceleratoin from this engine, your screwed. There are little accesories that will give you almost 20 Hp but nothing major.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #3 of 4 Old 01-27-2002, 01:24 AM
rollinashortysahara
surges in power on a fuel injected jeep are normaly caused by the notoriously poor manifold air pressure sensor also known as map sensor. it controls fuel / air mixture
supposedly adjusting for ambient air pressure but mine in a 94 4.0 sahara causes a drop in power around 2700 rpm in hard acceleration and a large jump in power about 3000 rpm.
http://www.turbocity.com/JeepStagePowerKits.htm has a kit to fix the problem
p.s. a turbo on a jeep would be golden but i don't know of a factory one ever built and the only turbo kit i do know of is also at this same web site.
rollinashortysahara is offline
post #4 of 4 Old 01-27-2002, 01:28 AM
rollinashortysahara
http://www.turbocity.com/jeep_parts_list1.htm
better discripton of the "rock-it map adjuser"
Slight grinding on accelleration Reverb YJ Wrangler Technical Forum 25 02-11-2014 07:59 PM
'90 YJ has not accelleration.. Jeeptor YJ Wrangler Technical Forum 3 12-23-2009 02:58 PM
Sluggish at 2k RPM JeF4y JK Wrangler Technical Forum 4 05-10-2007 04:18 AM
Squeak upon Accelleration FritzTJ TJ Wrangler Technical Forum 12 03-26-2007 01:53 PM
Accelleration Problem KU krawler TJ Wrangler Technical Forum 4 07-17-2003 11:27 PM
