Sloppy steering - JeepForum.com
post #1 of 5 Old 05-06-2010, 10:31 AM Thread Starter
jacobAnstett
Sloppy steering
theres about an inch of play in my steering wheel, i tried to adjust the steering box but it did nothing. i think the play is in the u-joint closest to the steering box on the steering shaft, i went to chrysler to see if they could show what i needed to do to fix it and they wanted me to buy a new shaft for around $450 is there another way i can fix this? im gonna look at local scrapyards today to see if i can get one cheaper. anyone have any idea????
jacobAnstett is offline
post #2 of 5 Old 05-06-2010, 10:40 AM
xdgt03
That joint is not repairable. It comes as an assembly with the lower shaft. The steering shaft is in two peices. However, especially in 4 season states/provinces they become fused by rust. It is sometimes very hard to separate them. The fact that they are fused causes the u-joints (particularly the bottom one) to fail early due to frame flex. If you can get your top and bottom shafts separated, I have a good bottom shaft. If not you will have to buy a used replacement (I did this), buy a new one from Crown (cheap crap), buy a performance one from 4WD or Quad for $250, or get the OE.
If you are in the Windsor area we could meet. I am in Ann Arbor so not far from the border. If you come to the states, feel free to PM me if you want to arrange shipping something here to avoid added shipping charges, etc...
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #3 of 5 Old 05-06-2010, 11:24 AM
Rocky_Cosmark
Check the bearing right above the top u joint, with a bad bearing u will get almost 2 in. of play in the whole column and sloppy steering, i know this because i replaced mine last weekend and it fixed that problem, its like $20 from quadratec for the part and an hr of your time, even if you need a whole new shaft u will need the new bearing, its the lower steering column bearing if you look for the part
Rocky_Cosmark is offline
post #4 of 5 Old 05-06-2010, 01:15 PM
Que89YJ
X2 The white puck that is at the bottom of the column just above the Ujoint. Its the lower steering column bearing.
http://www.jeepforum.com/forum/f12/l...t-pics-741968/
Que89YJ is offline
post #5 of 5 Old 05-06-2010, 02:46 PM
HilltopperYJ
I would check the bearing first and see if that takes play out before ******* out the big bucks for a whole new assembly
K Σ
A-E-K-Δ-B
ΜΟΛΩΝ ΛΑΒΕ!
HilltopperYJ is offline
Sloppy Steering Chip 7857 JK Wrangler Technical Forum 18 12-14-2008 10:36 PM
New Steering Column fixed sloppy steering. Oman Jeep TJ Wrangler Technical Forum 5 09-23-2008 01:59 PM
sloppy steering jeepsteve TJ Wrangler Technical Forum 5 12-16-2006 06:37 PM
How do I fix sloppy steering??? DanMan2540 TJ Wrangler Technical Forum 4 06-18-2005 06:53 AM
Sloppy steering Mark TJ-YJ TJ Wrangler Technical Forum 4 01-10-2003 01:38 PM
