Slave cylinder or synchronizers? - JeepForum.com
post #1 of 3 Old 01-20-2014, 07:21 PM Thread Starter
ahar9
So my 94yj has a ax15 external Slave and it's acting up. Sometimes the Jeep won't go into any gear and in reverse it will grind if I try to go into reverse and 1st - 5th it just won't go in at all. If I shut the Jeep off it will usually go into gear even without pushing the clutch. Sometimes it won't though. But when it's running sometimes it will shift like butter and sometimes it won't go into any gear unless I turn it off off and put it in gear then start it or force it into reverse. My friend said when I had it running and was in neutral when I pressed the clutch and went to put it in 1st he saw the back right wheel slightly move forward(tire off the ground) but it wouldn't go in gear. Every time I tried to go into 1st he said the tire would move. Don't know what's going on. Checked tranny fluid and it's brand new fluid and full. Any ideas?
hold my beer
ahar9 is offline
post #2 of 3 Old 01-20-2014, 10:03 PM
bigbossd1030
Try pumping the clutch pedal about 10 times fairly quickly. If you can then get it into gear it's your hydros. More likely your master cylinder. I suggest replacing the mc and sc. Get the kit and swap them both. 1 hour max and you're done.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 3 Old 01-20-2014, 11:09 PM Thread Starter
ahar9
But I kind of feel like my hydraulics are good because if I have the jeep off and I turn it on while in gear with the clutch pressed it won't lurch forward or anything. Also when it is driving good it shifts really smooth and the clutch always feels very nice. Could it possibly be the pressure plate? I'm going to try the pumping it 10 times thing and see. If it works I'll throw a new master and Slave on it tomorrow. And just because it might help I might drain a quart of fluid and add some syncromesh. The guy I bought it from said he just put a heavy duty center force clutch and pressure plate in.
hold my beer
ahar9 is offline
