Slave Cylinder - JeepForum.com
post #1 of 9 Old 09-14-2005, 09:01 AM Thread Starter
Toyandgadgetguy
Toyandgadgetguy's Avatar
Slave Cylinder
Anyone have a good writeup on the replacement of one?
Bad news is that mine went. Right in the middle of Queens, NY of all places.
Good news is that it now has self-changing fluid. I pour it in the top, and it comes out the bottom.
I tried the search, and found lots of advice, but didn't see a writeup... perhaps I missed it.
Yes, it's got rectangular headlights... it still says JEEP on the side! I've got the cool rollbars, so what?
Red JEEP club member # 267
Toyandgadgetguy is offline
post #2 of 9 Old 09-14-2005, 09:10 AM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
There isn't a write up but i just did mine last week. so ask me your questions......
FunkSkunk is offline
post #3 of 9 Old 09-14-2005, 10:12 AM Thread Starter
Toyandgadgetguy
I can't say as I have any specific questions regarding the project... I was just looking for a walkthrough on it. I like as much information as I can get before diving into something like this. The two manuals I have are very vague when it comes to the slave cylinder. I'll manage, I'm sure, but I like knowing what to watch out for before hand. It usually saves me some skin on my knuckles.
post #4 of 9 Old 09-14-2005, 01:21 PM
FunkSkunk
FunkSkunk's Avatar
OK replacing the slave cylinder is not bad. Its the getting to it part that sucks!
you'll be taking the tranny out (don't worry its not that bad) and moving it back or just taking it all the way out to get to the slave. O and what year is your jeep? 95 or so YJs have an external slave.
anyway....
you'll take out both driveshafts - easy
take off the skidplate - easy, but make sure you've got something to hold the tranny, ie tranny jack, piece of wood, floor jack, a buddy, etc.
disconnect all wires,vents, hoses, going to the tranny& t-case - easy
Take of the shifter boot, and shifters from the tranny - easy, just make sure the tranny is in nuetral (dont' forget to block those tires) and just set it inside the jeep
take all bolts off the bellhousing holding the tranny to the engine. - this is the worst part, most of these bolts are different sizes, should be all metric/unless someone has replaced them at one time with standard. also getting up at the top of the tranny blows and is hard unless you have a body lift or some good ratchet extensions. You'll also need to have PB Blaster on hand to get the bolts to let go.
Ok once all these are off (and all your knuckles are blood and you've used up all your cuss words) just back the tranny and tcase off the engine.
Once your in there clean it up and swap parts
then reverse the install.
HTH
* I would go ahead and replace the clutch too while you are in there. Even though its probably still good, its better to replace it now then do this whole mess again when it goes out, i did.**
post #5 of 9 Old 09-14-2005, 02:30 PM Thread Starter
Toyandgadgetguy
Thank you very much for the walkthrough. That's exactly what I needed.
It's an 89. It's internal. I put the fluid in... and watch it pour out of the housing. Luckily, it went out near my buddy's house, and I was able to nurse it there. Took all the fluid I had to make it the two blocks. I'll be cussin' like a sailor tomorrow, I'm sure.
Thanks again.
post #6 of 9 Old 09-14-2005, 03:16 PM
admar2
admar2's Avatar
just did this myself. do yourself a favor and drop the money on a LUK Pro Gold clutch kit. comes with EVERYTHING you need. might as well change the rest of it while you have the tranny rolled back!
do yourself a favor and beg/borrow/steal a tranny jack!!!! I can't believe how easily mine went back in. literally took me 5 minutes to get the tranny/transfer case mated back up with the engine.
if your 89 is like my 89 the two bolts at the top, that bolt the tranny to the engine are E12 torx bolts. make sure you have a E12 socket for those. those two bolts were the most time consuming part of the whole job for me!
admar2 is offline
post #7 of 9 Old 09-14-2005, 08:44 PM
Anthen27
Hey, I live in Merrick, LI where are you? I just did the same job in my buddies 93' YJ but we put a 99' AX-5 tranny and newer style clutch and slave setup in at the same time.....I woudl consider converting to the newer style exernal setup so you do not need to drop the tranny to replace the clutch slave.....you will need a newer style slave (about $75) would also need the newer style clutch fork and throwout bearing but I think it is well worth the upgrade (you can reuse your old pressure plate and clutch disk if it is in good shape)......I have a new slave that I didnt use because my buddies clutch master was also leaking so I replaced the whole clutch slave/master assembly from chrysler for about $175....and already ordered this slave from an online supply house and never bothered to return it...If you need it let me know I will let you have it cheap.......good luck.......
Anthen27 is offline
post #8 of 9 Old 09-14-2005, 09:17 PM Thread Starter
Toyandgadgetguy
Bay Shore, Long Island. I'm going to mull over the idea tonight. Unfortunately, I don't know enough about clutches to do much more than direct replacement as opposed to modification. Then again, I learn by doing, so it might be worthwhile... and I wouldn't have to worry about it the next time it happens.
post #9 of 9 Old 09-14-2005, 09:43 PM
enil01
enil01's Avatar
I was supposed to move to Bay Shore with my buddy, but I joined the Navy instead... boy was he pissed.
God luck tomorrow or whenever you do it. Seems like everyone's having the same problem all at the same time mine went last week we should have all gotten together and had a slave cylinder replacement party.
'93 4.0L YJ Becky
RE 4.5" XD lift | 33" TRXus M/Ts | Warn M8000 | Herculined | OBA
_|_
--X-X-(_)-X-X--
<3 EP-3Es
enil01 is offline
slave cylinder? DanyJeep YJ Wrangler Technical Forum 15 08-21-2011 03:36 PM
How do you know whitch one is bad, Master Cylinder or Slave Cylinder? Morgan_TJ TJ Wrangler Technical Forum 19 08-06-2008 09:00 AM
how to tell if ur slave cylinder is bad? Spigger73 YJ Wrangler Technical Forum 9 01-27-2008 06:14 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
slave cylinder help Cyanide96VR6 YJ Wrangler Technical Forum 10 10-14-2004 06:30 AM
