Skyjacker lift update - JeepForum.com
post #1 of 3 Old 07-29-2002, 07:52 AM Thread Starter
battlestar
I bad mouthed them two weeks ago becuase of the religious stuff they put in their kit, but I have to say that I do like the kit. The ride is a huge improvement over what I had before. When I bought the jeep it had some sort of rigged up lift, so I don't know what a stock yj is supposed to ride like so I can't compare it to that.
One thing I noticed though is that there is a little bit of oversteer/understeer. Is this common to lifted vehicles? Is it an alignment issue?
My Ride: 1990 YJ, 4.2, 5 speed, msd ignition, TFI Cap, 4" skyjacker lift, 1/2" shackles, nutter bypass, bestop seats, herculined floor, Flowmaster, Oversized cat, Xterrains on Rock Crawlers
battlestar is offline
post #2 of 3 Old 07-29-2002, 12:42 PM
St.LJustin
St.LJustin's Avatar
An alignment could help your problems. It is usually recomemded after a lift of 3.5 or more. Did you install a dropped pitman arm. If so, then the steering would probably need an alignment. If you didn't, then I would recommend it. Skyjacker makes them too if you didn't get one.
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #3 of 3 Old 07-30-2002, 03:03 PM
springfield45
2011 JK Wrangler
Just did the 2 1/2 w rancho 9000's and love it great ride. will do a 1" body lift. Did some 4 wheelin a couple weeks ago was great even a shot comin off the top of a hill with one wheel off the ground, got about 5-6k on it and no sagging either.
springfield45 is offline
skyjacker lift kit captbobrcc JK Wrangler Technical Forum 1 12-27-2008 10:45 AM
2.5 skyjacker lift 4x4dap YJ Wrangler Technical Forum 1 02-02-2008 07:41 PM
update: my lift install progress ginsy YJ Wrangler Technical Forum 4 08-19-2005 04:37 PM
Body lift update: day 1 SpedJeep YJ Wrangler Technical Forum 1 07-19-2005 04:32 PM
Update on 94 YJ, D44 install and lift springfield45 YJ Wrangler Technical Forum 0 06-24-2002 12:44 PM
