Skyjacker 3" Body Lift - Help and/or Suggestions - JeepForum.com
post #1 of 8 Old 04-07-2013, 07:43 AM Thread Starter
Tmp4of6
Have a 88 YJ (Base Model with 93" Wheel Base) Has a 1991 4.0 with a manual 5 speed. Running 32" x 11.5 x 15's. Looking to do a 3" body lift using Skyjacker's 3" Body Lift Kit # SJ-SS933 (Manual Transmission Only)
I am mechanically inclined but have never done a body lift, and don't want to get half way into it and start having problems. Would prefer to only do it once and do it right.
Do I need to be concerned about a new dropped pitman arm, an Slip Yoke Eliminator (SYE), Cross Over Steering Conversion Kit, Engine Mounts, Transmission Mounts, Extended Brake Lines, or Driveshaft Length?
Just like painting, it all about the preparation. Any and all help, suggestions, and comments appreciated.
Thanks, Dave
Tmp4of6 is offline
post #2 of 8 Old 04-07-2013, 07:47 AM
Camd94224
1989 CJ7
Guys around here have had a 3 inch body lift and they say they get cracks in their floors and it isnt good... Plus a three inch body lift looks stupid... IMO
1979 cj7 4.2, weber, 3 speed, 31x10.5r15
1977 cj5 4.2, weber fiberglass tub parts jeep
Camd94224 is offline
post #3 of 8 Old 04-07-2013, 07:56 AM
jeepcrazy93
He's right. They are a bad idea. If you want to do it right, do a suspension lift. Its more work but worth it. The skyjacker kits come with most of the things you will need minus a SYE/CV driveshaft.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #4 of 8 Old 04-07-2013, 08:22 AM Thread Starter
Tmp4of6
3" Body Lift Help
Thanks for the info and help. After what you have said, think I am going to look into a suspension lift.
Tmp4of6 is offline
post #5 of 8 Old 04-07-2013, 08:29 AM
phil1330
1964 CJ5
Body lifts are OK. 3'' does look retardEd. I got a 2'' body lift on mine and I've had no issues with it at all. But most people on this forum would prob agree not to go any higher than a 1.5 Body lift .
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #6 of 8 Old 04-07-2013, 09:43 AM
jeepcrazy93
I have a 1" BL on mine and its fine but 3" your asking for issues. Whatever lift you decide on invest in some PB Blaster and let the bolts soak at least overnight. It will be your friend.
post #7 of 8 Old 04-07-2013, 09:46 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't buy skyjacker springs. Trust me on this.
Luck Favours The Prepared
Anticanman is offline
post #8 of 8 Old 04-07-2013, 10:12 AM
UZI4U
Do a 1" BL and the rest with your suspension...that is the right way. Go with the Daystar lift and you'll only do it once. I went with the plastic spacers and I'll be replacing them before too long because I was being cheap.
MCLMM
UZI4U is offline
