Skid Plate removal? - JeepForum.com
post #1 of 10 Old 02-14-2014, 11:42 PM Thread Starter
231Jeeper
Skid Plate removal?
I need to remove the skid plate on my 95 yj and I notice you have to support the transmission when doing this. Whats the best way to do this? and is the skid plate the only thing holding it all up??
Thanks.
I don't steer my Jeep. It's more like I guide it.
231Jeeper is offline
post #2 of 10 Old 02-14-2014, 11:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Put a jack under the transfer case output shaft and then drop the skid plate.
Luck Favours The Prepared
Anticanman is offline
post #3 of 10 Old 02-15-2014, 12:29 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Yup...Skid plate acts as the transmission support/back end of engine support. Jack/jackstand under the back end of the T case. 3 bolts down each side into the frame rails, but also there are 4 closely grouped in the middle of the skid plate that holds the actual tranny support to the skid, then one more that is the torque arm to the T case on the driver's side of the skid plate. Gotta take all these off to drop the plate. The 6 bolts of the plate to the underside of the frame rails can be problematic, and can be rusted/frozen into place and wring off, or spin the captured nuts inside the frame rails.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 10 Old 02-15-2014, 05:07 AM
Louie4
I typically put a piece of wood or cardboard in between the jack and the tranny/engine...if I have it available but that's just me.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #5 of 10 Old 02-15-2014, 11:37 AM
bpounds
bpounds's Avatar
I put the jack under the bell housing. I don't guess it really matters, as long as you support it. If you don't, you'll experience a surprise. You'll likely have a surprise anyway when you try to remove those 6 frame bolts.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 10 Old 02-15-2014, 12:31 PM
fratis
fratis's Avatar
I always put the jack under the tranny.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #7 of 10 Old 02-15-2014, 02:29 PM
92Islander
skidplate and frame bolts
All good suggestions ! The frame bolts are lots of fun. I used a socket and a 4 foot pole from my floor jack. Was still hard to break the bolt, but it worked. I was afraid it was going to snap, but did not
All the world is indeed a stage and we are merely players, performers and portrayers, each anothers audience...
-Neil Peart of Rush, Limelight.
92Islander is offline
post #8 of 10 Old 02-16-2014, 10:09 PM Thread Starter
231Jeeper
Thanks for all the great info.
My tranny mount only has 2 bolts under skid plate. I think its this one. Guess that normal for a 95 with ax-15 tranny?
http://www.extremeterrain.com/omix-a...609&adtype=pla
post #9 of 10 Old 02-16-2014, 10:43 PM
Opihi59
Opihi59's Avatar
Hmmmmm. I suppose I have not seen a 2-bolt mount thru the skid plate, but that doesn't mean it doesn't exist. Mine have all had 4 fasteners thru the skid plate. Let us know how it all comes out for you.
Opihi59 is offline
post #10 of 10 Old 02-17-2014, 12:07 AM
88_olympic
I have that mount just mentioned. There is an additional bolt that goes through the skid to the tourqe arm. 3 nuts to remove on mine plus the frame bolts. Heavy on the pb blaster before hand and you. will hopefully be fine. If not there are some good threads that address what to do from there. Good luck and be careful when the skid comes down, i always put the jack under the pan with a piece of wood in between and don't it jack up, just enough for support. and put one jack stand on each side of the skid plate so it doesn't fall. Much more easy with 4 hands but very doable solo
88_olympic is offline
