Skid plate bolt question.. - JeepForum.com
post #1 of 5 Old 07-24-2013, 08:47 PM Thread Starter
cgseanp
My Jeep has the tcase drop kit installed and i also have a cv rear ds and sye so i am removing the drop... Question is, how long are the bolts supposed to be without the drop? Are they the same bolts? I figured they'd be longer since there are the 1 inch spacers between them. I attempted to put the bolts back without the spacers and they go until there is about 1/8 inch left and then stop.. I could probably crank them down but want to make sure they aren't too big... The bolts i have are approx 2 inch long. Thanks!
cgseanp is offline
post #2 of 5 Old 07-24-2013, 09:11 PM
rambo3489
The are not the original bolts. They are likely longer, and you are probably bottoming out the shoulder.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 5 Old 07-24-2013, 10:08 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
They are longer bolts. 1" longer approx. So you'll need to get shorter ones by at least a half inch.
Michaelgoesrawr is online now
post #4 of 5 Old 07-25-2013, 05:52 AM
kloppk
The overall length of the bolt isn't the issue.
If the bolts look like this then they should be OK. (Threaded all the way to the head of the bolt.)
If the bolts look like this (not threaded all the way) then they may not work. The unthreaded portion may be bottoming out on the nutsert in the frame before the skid plate is tight against the frame..
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #5 of 5 Old 07-25-2013, 07:25 AM
coupleofjeeps
I used the same ones when I removed mine, so they may work. Pull one and look and the threads/length first.
93 ZJ, 98TJ, 03KJ, 04WJ - SOLD
HIS - 92YJ - mildly built - oh the places we'll go...
HERS - 2002 WJ Overland
coupleofjeeps is offline
