Size of helicoil for caliper bolt/stripped knuckle repair? - JeepForum.com
post #1 of 9 Old 05-20-2007, 03:42 PM Thread Starter
Alheim
Hey all:
Today I was putting on new brakes, and tie rod ends, and I found out upon reinstallation that, on one side, the knuckle threads are stripped - the ones that mate to the caliper bolts.
I think I'm going to fix it with a helicoil, but I don't know what size to buy. Would it be easy to buy a whole kit? Do I have to buy a whole kit? The guy at Pep Boys on the phone made it sound like they only sell individual sizes, and I have no idea what size to buy.
If nobody knows.. can I just measure my bolt at the threads to get the right size?
Thanks a lot,
Alheim
'95 YJ 123bhp 4-banger powerhouse.
UPDATE: 2.5L ENGINE RETIRED; she was still running strong at 212,000mi.
4.0 swap in progress.
Alheim is offline
post #2 of 9 Old 05-21-2007, 09:05 AM
kickin chicken
take the bolt with you and they will help you find the correct size.
jeremy
kickin chicken is offline
post #3 of 9 Old 05-21-2007, 02:28 PM
OhioYJ
I want to say its either M8x1.25 but it may have been M8x1.5. I had to do one in my steering knuckle too. I bought the kit, as you need a special tap for it, and you'll have to buy the drill bit separately. The drill bit the kit called for was some really odd ball ??/64 bit, that I had to go to a hardware store to find, the auto parts place didn't have it.
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things.
-- Mike
OhioYJ is offline
post #4 of 9 Old 05-21-2007, 05:20 PM
davidm89
What size/ thread count are those? We could not figure it out when i had the same problem. I got it threaded into the hole but it wouldn't tighten. I had to use locktite, but there is only lateral force on those bolts, so it has worked well
davidm89 is offline
post #5 of 9 Old 05-21-2007, 05:50 PM
zman
That's the one. You can get the kit at Ace Hardware for around $25. It will have everything you need.
zman
1995 YJ on 40's * 2002 TJ on 37's * 2003 TJ on 33's * 2011 WK Larado X w Hemi
zman is offline
post #6 of 9 Old 05-22-2007, 10:50 AM Thread Starter
Alheim
zman
Thanks guys. I got the M8x1.25 at PepBoys (PermaCoil) and it worked perfectly - it's a really cool repair method and it's really neat how perfectly they are machined - the fit and strength is awesome.
Alheim is offline
post #7 of 9 Old 05-22-2007, 12:40 PM
Ustabearenegade
Ustabearenegade's Avatar
saw this too late - I had that happen to me a few years ago - the problem i had with the helicoil is that it likes to back out after a while. I tried eveything on it to get it to stay put and even tried a few other ones - still wanted to back out. I ended up using red locktight on the coil to prolong the tension on the fix but it only lasted a while. Good luck just be sure to check it and carry a few extra caliper bolts with you.
"Negative....I am a meat popsicle"
Ustabearenegade is offline
post #8 of 9 Old 05-22-2007, 06:36 PM Thread Starter
Alheim
Thanks. What did you do or what are you going to do after the locktight fix - time for a new knuckle?
Alheim is offline
post #9 of 9 Old 05-23-2007, 06:46 AM
Angelous
1987 YJ Wrangler
Autozone carries oversized caliper bolts.
"There is no hole to deep, or mountain to steep, for the driver of this Jeep!"
87 YJ - 2.5 - TJ Flare Swap - Rubicon's - no track bars -
Angelous is offline
Stripped Brake Caliper Bolt at the knuckle JeepRocks86 TJ Wrangler Technical Forum 19 05-08-2010 07:59 PM
Caliper bolt stripped, how to get off? TheDragonfly TJ Wrangler Technical Forum 33 12-22-2009 08:52 AM
Knuckle threads for Caliper bolts STRIPPED sebastian22 YJ Wrangler Technical Forum 16 12-15-2008 08:24 AM
Bottom bolt on front brake caliper stripped athos76 TJ Wrangler Technical Forum 1 08-09-2008 05:41 PM
Helicoil for Stripped Front Caliper?? gtospeeding TJ Wrangler Technical Forum 22 09-08-2007 10:50 AM
