Size of 2.5 and 4.0 Throttle Body - JeepForum.com
post #1 of 7 Old 09-16-2012, 09:33 PM Thread Starter
TA-YJ
Can someone give me the measurement for the size of the two throttle bodies that mates to the manifold? I picked up a rebuild engine that came with a TB and I wanted to double check if it was a 2.5 or 4.0. Thanks.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #2 of 7 Old 09-17-2012, 05:05 AM
Duncan542
Not sure on the 2.5 but 4.0 is either 60 mm or 62 mm.
Duncan542 is offline
post #3 of 7 Old 09-17-2012, 08:13 AM Thread Starter
TA-YJ
Any way you could take a measurement? I thought the 4.0 was less than that bc the 62mm was an upgrade for it
1992 YJ 2.5L
TA-YJ is offline
post #4 of 7 Old 09-17-2012, 12:14 PM
Que89YJ
http://www.jeepforum.com/forum/f12/2...y-swap-602123/
Originally Posted by 4bangerYJ View Post
The stock 2.5 TB is 48mm
The stock 4.0 TB is 55mm
The gasket is 62mm.
Que89YJ is offline
post #5 of 7 Old 09-17-2012, 01:10 PM
mrdeath2000
you can get the 4.0 bored.
get it from someone reputible, if they go to 62mm bore and it's not done right it will whistle. you can push it to 63mm i think, but it's not advised. some only go to 60mm, still plenty big... hell stock 4.0 at 55mm is plenty big unless you start playing with fuel pressures with an adjustible regulator and/or playing with MAP voltages.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #6 of 7 Old 09-17-2012, 06:56 PM
Duncan542
I have heard alot of people have better luck with 60mm rather than 62mm
post #7 of 7 Old 09-19-2012, 11:24 AM Thread Starter
TA-YJ
Thanks for the measurements! Got everything squared away.
1992 YJ 2.5L
TA-YJ is offline
Jeep thinks its a toyota... stuck throttle and oil around/in throttle body benlee248 TJ Wrangler Technical Forum 27 12-01-2011 12:29 PM
How Do You Remove the Throttle Cable to the Throttle Body? JustChillin TJ Wrangler Technical Forum 3 10-23-2010 01:52 PM
What size throttle body to go with???? haulincats TJ Wrangler Technical Forum 3 09-12-2009 07:25 PM
throttle body and throttle body spacer laxin15 TJ Wrangler Technical Forum 11 08-24-2009 02:47 PM
2004 throttle 4/0 throttle body on 95 2.5? Ironworker709 YJ Wrangler Technical Forum 1 02-04-2009 02:30 AM
