Sirius antenna mounting - JeepForum.com
post #1 of 13 Old 11-08-2006, 08:50 PM Thread Starter
mrobertson
Just got a sirius sportster satellite radio. Leaving the antenna on top of the dash doesn't get a very good signal. I have the soft top on right now so attaching to the roof won't work.
Is there someplace you guys mount the antenna to get a good signal?
mrobertson is offline
post #2 of 13 Old 11-08-2006, 08:56 PM
BuffaloYJ
BuffaloYJ's Avatar
I bought 2 exhaust clamps, popped them on the roll bar (flat side up) and just stuck the magnet to the flat pieces. Ran the wire under the rollbar pad, and was done. Works great through my soft top.
BuffaloYJ is offline
post #3 of 13 Old 11-08-2006, 08:57 PM
CNY
Caught ridin' dirty
Under the roll bar pad.
Works fine, hard or soft top
CNY is offline
post #4 of 13 Old 11-08-2006, 08:59 PM
dbikers
I had a piece of sheet metal that i zip tied to the top of my roll bar with 2 zip ties, antenna magnet stuck to sheet metal.
Great signal through soft top
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #5 of 13 Old 11-08-2006, 09:03 PM
sequel
Mine sits on top of the speaker bar over the passenger side speaker. There is a fabric flap that wraps around the roll bar and velcros to the top of the speaker bar. I put the antenna underneath that (there is some metal there that the magnet can rest on), ran the wire down the rollbar padding with the speaker wire harness and followed the harness all the way to the dash. Works great, top on or off.
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline
post #6 of 13 Old 11-09-2006, 03:35 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
I centered mine on the dash, hard or soft top perfect reception. I just used a dab of rtv to hold it in place.
- Ernie
Richmond88yj is offline
post #7 of 13 Old 11-09-2006, 08:03 AM
93Renny
Saw a newer wrangler with it mounted on the cowl just to the left (driver side) of the hood vent. Looked alright
1993 Jeep Renegade, 4.0 I6, 2.5 Rubicon Express Lift kit, 1 inch Shackles, BFG 32x11.50x15
Other add ons, TJ style Stainless hood catches, custom tow hitch......
93Renny is offline
post #8 of 13 Old 11-09-2006, 08:31 AM
pezley69
I have mine under the roll bar padding as well....works just fine.....I just unzipped it a bit and shoved it in....and then ran the wire down the bar....
05 Black TJ Rubicon 2" Spring lift, Hella 500's on the windshield, SRC front bumper, SRC rear bumper w/ tire carrier, SRC rocker guards/steps, Mile Marker PE8000 winch
pezley69 is offline
post #9 of 13 Old 11-09-2006, 08:33 AM
Skeezer
I put mine on the hood in front of the windshield, great reception.
2005 Rubicon
Skeezer is offline
post #10 of 13 Old 08-24-2013, 10:36 AM
Deuce2
My antenna is round and fit perfectly on top part of windshield frame, passenger side. I have no roof so the wire runs neatly down inside of frame tucked under rubber molding.
Deuce2 is offline
post #11 of 13 Old 08-24-2013, 11:55 AM
Cooter92YJ
I sandwiched a short length of 1/8" x 1" angle iron between the windshield frame and the loop above the rearview mirror. It gets it up out of the way, plus great reception.
Originally Posted by Luuca
Welcome to the wonderful world of YJs... you'll soon learn how to listen, feel, and smell your way into vehicle diagnostics!
Cooter92YJ is offline
post #12 of 13 Old 08-24-2013, 02:11 PM
Chefdanb
Chefdanb is offline
post #13 of 13 Old 08-24-2013, 02:22 PM
AmmitOsiris
AmmitOsiris's Avatar
Mines on the cowl on the driver side.. I still need to buy the service but when I had the trial it worked great
Sent from Peggy's office
AmmitOsiris is offline
factory sirius antenna DVR TJ Wrangler Technical Forum 5 04-12-2011 09:30 PM
Sirius satellite radio antenna dealrocker Wrangler General Discussion 4 01-19-2010 04:47 PM
Where is Sirius antenna located? MacK JK Wrangler Technical Forum 20 07-23-2009 09:58 PM
Sirius Satellite Antenna Mount Kevin_G JK Wrangler Technical Forum 13 07-25-2007 04:33 PM
Sirius Antenna ksjeep226 JK Wrangler Technical Forum 6 05-28-2007 09:32 PM
