single point injection fuel system problems - JeepForum.com
post #1 of 10 Old 03-22-2009, 04:56 PM Thread Starter
humboldtjeeper
i have a 1990 wrangler 2.5L with the single point injection. i rebuilt the whole jeep a few years ago including the fuel system. ever since then i can only use half of my tank. it cuts out and dies at about 100 miles roughly 9 gallons. i have tried everything. i bought 2 new pumps new lines a new tank new filters everything.. i am tired of fillin up with fuel everyday does anyone have any ideas?
humboldtjeeper is offline
post #2 of 10 Old 03-22-2009, 05:05 PM
Douglas S.
That's strange, what makes you think it has something to do with the TBI? Could there be a hose in the tank that isn't reaching the bottom? Is the tank ventilated properly?
1991 Land Cruiser HDJ81
Douglas S. is offline
post #3 of 10 Old 03-22-2009, 06:06 PM Thread Starter
humboldtjeeper
well im not sure its the tbi but i just replaced the hose inside the tank about 2 months ago. and i also revented the tank. i have a parts jeep same year and engine its identical. i stole the vent hoses of of it. i have a new tank new lines new pump new filter new vent lines new seals new fuel cap everything. i have replace everything from the tbi back. its almost like its picking up air. it will cut out then it will restart but as soon as i take a turn its cutting out again. and its alway runs out after it has used 9.5 gallons. i have asked all the local shops and no one has any idea. i did take all the smog gear off of it. that could possibly be the reasoning too.
post #4 of 10 Old 03-22-2009, 06:52 PM
ghost183
single point injection = TBI, throttle body injection.. same thing
do you remember what the intank pump looks like?
similiar to this setup ? this pump and acc bolt onto the tank cap and go inside the tank..
if so? see that hose? that hose extends the pickup down further into the tank.. your hose is probably too short.. lengthen it till the filter is about 1 1/2 inches from the bottom of the tank, its ok if the hose isnt clamped to the railing of the cap, as long as its clamped onto the pump and the strainer clamped onto the hose good.. everyting will be fine..
Important Notice:... DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE............ Regards:... THE GOVERNMENT
ghost183 is offline
post #5 of 10 Old 03-22-2009, 07:04 PM Thread Starter
humboldtjeeper
i actually checked that and replaced the hose recently. when i toke it apart i did check how far the assembly went down and it was practically touching the bottom of the tank. im almost certain its not the pump assembly. but then again it doesnt seem logical that it would be in the tbi end of the system either.
post #6 of 10 Old 03-22-2009, 07:10 PM
ghost183
hmmmmm... thats intersting.....
off i go to brainstorm
ghost183 is offline
post #7 of 10 Old 03-22-2009, 11:59 PM Thread Starter
humboldtjeeper
yeah im out of ideas. if you find something let me know please
post #8 of 10 Old 03-23-2009, 11:09 AM
don2510
Had a car that would do the same thing. Found that the nipple on the inlet side the the pump had a hairline crack in it and when the gas level got below the bottom of the pump, it would suck air and cut out. I would pull the pump and check all the connections below the pump (clamps, hose for pin hole, nipple for cracks).
don2510 is offline
post #9 of 10 Old 03-23-2009, 03:35 PM Thread Starter
humboldtjeeper
yeah thats possible because the fuel would shift to the side around turns. ill check that out thanks
post #10 of 10 Old 03-25-2009, 06:55 PM Thread Starter
humboldtjeeper
tried it thats not it... but i blew my transfer case again so the fuel is the least of my worries now.
Can someone please point me in the correct direction for an 05 TJ Switch POD/Single Neeco TJ Wrangler Technical Forum 16 09-20-2009 04:34 PM
Idleing problems/fuel injection issues? jesseleikerjeep YJ Wrangler Technical Forum 8 06-17-2009 01:38 PM
1987 fuel injection system square87 YJ Wrangler Technical Forum 12 03-10-2009 08:15 PM
some one inform me on the multi and single port fuel injection toates89 YJ Wrangler Technical Forum 10 05-07-2007 03:53 PM
Whistling noise from Howell fuel injection system brgc222 YJ Wrangler Technical Forum 3 05-04-2007 08:25 AM
