Simple YJ to suit my needs - Page 3 - JeepForum.com
post #31 of 45 Old 10-19-2012, 09:07 AM Thread Starter
richharr
That was lindenwood queens, right off of the belt pkwy, its like a square mile of co-ops. They all look the same.
93 4.0l 5 spd, 33s 4" lift
1. This forum requires that you wait 60 seconds between posts. Please try again in 1 seconds.
richharr is offline
post #32 of 45 Old 12-17-2012, 05:36 PM Thread Starter
richharr
Threw on a 12000# hf winch. Using it to pull stumps, pretty good so far
richharr is offline
post #33 of 45 Old 12-17-2012, 05:53 PM
GilNewJeeper
2008 KK Liberty
Nice Jeep, Still at Lindenwood?. I just to leave at Howard Beach by 84ST and 151AV.
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #34 of 45 Old 12-17-2012, 08:03 PM Thread Starter
richharr
No, up in putnam county for the last 4 months
richharr is offline
post #35 of 45 Old 12-17-2012, 08:49 PM
GilNewJeeper
2008 KK Liberty
I see, unusual to have such a big backyard in NYC.
2008 Jeep Liberty
post #36 of 45 Old 12-17-2012, 09:01 PM
uhohthe50
Looks good. Keep it up!
uhohthe50 is online now
post #37 of 45 Old 12-18-2012, 03:49 PM Thread Starter
richharr
Dropped 3 trees and pulled the stumps with the winch, takes longer to set up than to pull them out.
richharr is offline
post #38 of 45 Old 12-24-2012, 05:25 PM Thread Starter
richharr
Mounted the solenoid under the hood, going to put the remote outlet in the grille and make an in can switch next
richharr is offline
post #39 of 45 Old 03-08-2013, 07:01 PM Thread Starter
richharr
Working on my tub
Boatsides
Cowl vent delete
Cj tailgate
And rust repair of coarse..
Also looking to trade my 4" black diamond springs for 2-2.5" springs
richharr is offline
post #40 of 45 Old 03-09-2013, 03:11 AM
kgb_m3
good work man. what size tire will you be running after you "lower" the jeep? if you were closer, id be interested trading springs
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #41 of 45 Old 03-09-2013, 11:47 AM Thread Starter
richharr
33s, im just going to get rid of sheet metal to compensate
richharr is offline
post #42 of 45 Old 03-09-2013, 12:10 PM
kgb_m3
Interesting.. I would like to see 2" to 2.5" lift with 33s as I'm in the market for 33s myself.
Tube fenders up front and TJ smittybilt body armor flares in the rear trimmed to fit should do it. Trying to stay away from body lift.
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
post #43 of 45 Old 03-09-2013, 08:47 PM Thread Starter
richharr
I was considering 33s on 5/8" shackles and a 1" bl and a lot of cutting. I dont want to go smaller than the 33s i have now, but i want to get as low as possible with out sacrificing up travel
Still to cold out to plan the tub swap so i have some time to work and plan. Cut out the tail light holes and flipped the joop on the drivers side
richharr is offline
post #44 of 45 Old 03-26-2013, 05:55 PM Thread Starter
richharr
Got the driverside boatside 95% welded up. Only a few small repairs to the tub and its getting swapped, next 2 weeks i hope. There are 2 rust spots that ill get to when its on the road and around the time i tackle the cage
richharr is offline
post #45 of 45 Old 05-30-2013, 09:02 PM Thread Starter
richharr
Slow progress
richharr is offline
A not so simple, simple way to upgrade the stock JK stereo goldenglory18 JK Wrangler Technical Forum 71 04-19-2016 11:23 AM
1 simple question with 1 simple answer Anti-bling TJ Wrangler Technical Forum 2 12-17-2007 06:35 PM
Class Action Suit mibble98 TJ Wrangler Technical Forum 91 02-25-2007 04:53 PM
Suit Jacket MikeBW TJ Wrangler Technical Forum 11 08-30-2006 07:19 AM
i have my my flame suit on........ Maximummud YJ Wrangler Technical Forum 3 03-30-2006 08:35 PM
