Simple question: removing exhaust hanger - JeepForum.com
post #1 of 5 Old 05-01-2005, 02:05 AM Thread Starter
kaffeene
What is the best way (or only way) to remove the exhaust hanger from the black rubber insulator. There is that tappered end on the hanger that will slide in but can't slide out so easily. I could easily cut it off and pull the hanger out but I don't want to do that if possible. Just wondering if there was a trick to doing that.
I know this is probably silly or the answer is right in front of me. Thanks
12' JKU Rubicon
kaffeene is offline
post #2 of 5 Old 05-01-2005, 02:12 AM
mrgeoff
I always took the exhaust loose from engine, or if tou want to up grade, cut it up with saws all
93, 4 bangin, gutless yj that is ready to crawl this summer.
mrgeoff is offline
post #3 of 5 Old 05-01-2005, 02:12 AM
RabiDaWise
RabiDaWise's Avatar
Try PB Blaster or WD-40....those should slick it up enough.
Redneck Jeep Club Member #18
CSA Jeepers Association
'88 Wrangler Laredo, I6, Auto, 3" Body Lift, 33"x12.50" Destination MTs, Nutter'd w/ HEI, 32/36 Weber, LOTS more to come
"Ran into a chum with a bottle of rum and we wound up drinkin' all nite" Jimmy Buffet
RabiDaWise is offline
post #4 of 5 Old 05-01-2005, 02:28 AM Thread Starter
kaffeene
Well its not really removing the exhaust itself although I will have to do that from the beginning of the cat and back. But more for removing the hanger that holds the exhaust up and getting it to come out of the black rubber insulator without cutting. There is 2 that I will have to remove, one at the end of the muffler and one at the tail end.
12' JKU Rubicon
kaffeene is offline
post #5 of 5 Old 05-01-2005, 01:41 PM Thread Starter
kaffeene
Ok we can end this topic. I used liquid wrench and just pulled hard.. It accually popped right out. New Borla and highflow s.s. cat is on and has a bit more of a grumble.
12' JKU Rubicon
kaffeene is offline
Exhaust Hanger, isolator on transmission 4.2 stock exhaust Chris Aunchman YJ Wrangler Technical Forum 5 07-21-2009 08:11 AM
Need a exhaust hanger andrewf09 YJ Wrangler Technical Forum 3 06-15-2009 07:32 PM
Exhaust hanger SteveJcoYJ YJ Wrangler Technical Forum 7 05-28-2009 06:22 PM
Exhaust hanger 3stripes TJ Wrangler Technical Forum 1 04-02-2007 12:25 PM
Exhaust hanger missing milehighclub TJ Wrangler Technical Forum 2 01-03-2007 08:15 PM
