08-21-2008, 06:23 PM
#1
ok Guys my signal arm was snaped off by some kids in the wal-mart parking lot and my rig was not the only one unfortunatly they were not caught...... ok now this arm is also for my wipers and high beams it broke off with a small peice of the metal arm still inside the colum and i do have a replacement from the wrecker but i have no idea how to remove the little peice still stuck inside the colum... any ideas or suggestions?
08-21-2008, 06:32 PM
#2
can you drill it out and tap it for a small screw like a 6-32 or maybe 4-40 and use a screw to pull it out ? im not sure if it would spin if you tried to drill it. probably throw some vasaline on the bit if your worried about getting metal chips in the column. just a thought, may or may not work out
08-21-2008, 06:44 PM
#3
Got my eye on you.....
If that doesn't work for ya, go down to autozone and rent the wheel puller and lock ring depressor. Around $30 but you get all that back. Now set aside about an hour to work on it and you can get the column torn apart to get down to the switch. Here is a step by step write-up that will help you thru it. Yes it is for a CJ but it is the same GM column. : http://www.epiccomputer.com/dale/jee...tilt/tilt.html
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
08-21-2008, 06:58 PM
#4
had same problem... i left it alone for so long i needed a whole new switch which i got out of a part out... it was kind of a pain the first time feeding wires through the steering column... its not that bad though when we did it with no help
1994 yj. lifted 4 inches locked, loaded, and armored!
Member of Great Lakes Jeep Thing
and supporting jeeps gone wild
08-21-2008, 08:43 PM
#5
Location: Stuart, 30 miles north of West Palm Beach, Florida
I did what Rusty suggested, and it worked great!  I had the same problem, went to flash a truck so he could move in front of me, and it snapped and fell in the floorboard! I was able to turn the wiper switch off (mine was on at the time it snapped) by using a couple of dentist picks, then, push from the inside out the stub that was still in the switch. Put everything back together, and just pushed the new arm in, and I was in business. Just be careful about the high-low beam shaft that comes to the signal switch, it's a PITA to put back in right,  . Good luck!!
Jerry
1992 Jeep "CJ9" (YJ with '78 CJ front clip, '80 CJ Tailgate, Custom CJ Dash with '76 CJ Gauges) AX-15 from a '93 YJ, 2.5" Rancho SL, 5/8" MORE booms, 1" BL, and 33"x10.50" SS TSL's
08-21-2008, 09:09 PM
#6
Never could get that rod for high/low beams back in right, so I got a floor mounted switch for a cj.
08-21-2008, 09:12 PM
#7
Neither did I, laredo89! I gave up, not enough fingers or fingers not small enough, LOL  I haven't done anything with the hi-low beam switch yet. Was thinking of going the on-the-floor route for mine as well, good idea!
Jerry
08-21-2008, 09:32 PM
#8
thanks everyone ill give it a try tomarrow after work keep your fingers crossed!!!!
J.E.E.P = Just Empty Every Pocket
How true it is!!
