Quantcast sigh... more clutch related issues... i hope? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > sigh... more clutch related issues... i hope?
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 02-24-2005, 11:02 AM   #1
hmk_21
sigh.. where to begin, in the now 2 years I've had this jeep, i've had the tranmission out close to 5 times...
first the slave, disc.. tranny, slave.. etc etc.
ANYWAYS, after a swap AX-15 from a peugot this last month, i was hoping it would be fine. wake up this morning to a screetching sound whenever the clutch in engaged...
what could this be? something metal vs metal trying to spin i guess..
most likely the slave pressure plate grinding on the clutch disc? not sure....
help
89 Yellow YJ Islander 4.2L *decal free*
[url]http://www.cardomain.com/id/89yj_kmh[/url]
hmk_21 is offline   Reply With Quote
Old 02-24-2005, 03:43 PM   #2
hmk_21
it sounds ALOT like the throwout bearing/slave destroying itself...
this is the 3rd time.
why is this happening..
Old 02-24-2005, 06:27 PM   #3
Pcghost
When you swapped the tranny and clutch parts did you have the flywheel resurfaced? Or at least put a dial indicator on it to look for run-out. Misalignment could be eating your components.
'87 YJ Chevy 283, SM465, NP231, Ford 8.8's, 31x10.5's
--------- Conversion in progress --------------------------
Pcghost is offline   Reply With Quote
Old 02-24-2005, 08:24 PM   #4
hmk_21
educate me quick...
flywheel = clutch disc? pressure plate?
not sure with the terminology.. still "new" to this.
thanks
Old 02-24-2005, 08:26 PM   #5
hmk_21
hey, just googled it..
and no i didnt, should i have?
it'll be apart this weekend regardless..
is it recommended i do get it resurfaced?
thanks
Old 02-25-2005, 01:51 AM   #6
mr_man
Last month I had my tranny out 3 times, I feel your pain.
During my clutch job (that turned into a mini overhaul and tranny swap) I had my flywheel resurfaced at a nearby auto parts store that has a little machine shop. I'm no expert but the Haynes manual and people who know recommended I do this. It took a lot of effort to remove and reinstall the flywheel bolts, this would have been a lot easier with air tools. Anyways, since reinstalling everything last month all has been good and I'd say it's worth doing.
I can't help you with the screeching noise besides saying to double check that everything is attached properly and aligned. My new clutch squealed or chirped a little bit when engaging for the first few days, not loud enough to make me think there was something wrong though.
Green '94 YJ 4cyl 5spd, 126k mi
Pretty much stock except for my transmission (from a '98 TJ) and a few exhaust parts.
mr_man is offline   Reply With Quote
Old 02-25-2005, 11:36 AM   #7
Wif
You should always resurface the flywheel .. remove the polished surface and ridges. The small amount of hassle getting it off and away to machining versus having to do the whole job again down the road is a no-brainer. Mine was the original clutch .. 17 years old with 200,00 kms on it.
I've just done mine .. now freshly machined .. along with a complete clutch kit (pilot bearing, slave, pressure and driven plate).
Your squealing sounds like either the throw out bearing running dry or the bearing has siezed and is rubbing on the pressure plate fingers .. time to have it apart again .. 6th time lucky ??
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote
Glock Forum
