#1 | |
Side View Mirrors Anyone??
Has anyone had any luck finding a good set of sideview mirrors that fit on the body so the doors can come off. I have bought a set that attaches to the lower window frame hinge but the whole thing is crap from the mirror, to the paint, to the fasteners it came with, to the geometry of the passenger side one so you can see it.
If anyone has bougth a pair that works and good quality I would love to know the name and pics if you have any. Thank you! Jim
93YJ 2.5L,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 31" Pro Comp M/T's with MT Classic II Wheels, Herculined Inside, Flexalite Fan,4.0L Throttle Body, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bestop Extended Flares,AMSoil/Redline In Everything and the List Goes On.... AND... 88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater. |
#2 |
if you have light mounts welded on the front right below the windshield you can unscrew the mirrors and insert them into them..works for me, but you cant put aux. lights in
Get it Dirty |
#3 |
I've also seen it done with older pickup truck mirrors bolted through the upper door hinge.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully. |
#4 | |
#5 | |
Jello Puddin'
I got of CJ style windshield hinges and CJ mirrors. Works fine for me, but the passenger side takes a lot of adjustment to get it to where you can see anything. I think any mirror that mounts forward of the stock location on the passenger side is going to be that way because you have to view it through the windshield. I noticed the same thing on my Brother-In-Laws TJ with the mirror relocators. Other than that the only other thing I've noticed is that they do vibrate more than the stock door mirrors, but I've gotten used to that.
These may be similar to what you've already got, my buddy has some like you're describing and hates them. ![]()
#6 |
Picked up a set at Shucks auto supply - $15 each - 4.5x6 rectangle shaped, stainless steel. Will be using them on some safari doors I'm making but the hardware that came w/ them could easily be adapted to fit something that drops into your door hinges (checked several stores and one junk yard for side mirrors - these were by far the best looks wise)
#7 | |
KMG365
89 YJ Transplanted '99 4.0, AX-15, NP231 Red Jeep club #8 97 ZJ Laredo 4.0, 42re, NP242 Was my daily driver, now son's college partywagon. |
#8 |
Use mirror relocation brackets for the factory half door mirror
91 Sahara 4.0l Operation Welcome Home Parade Veh #69 PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift K&N Drop in and loaded with battle scars www.americaisfull.com FOR SALE 2005 PT CRUISER CONVERTIBLE 2005 Suzuki DRZ400S For SALE Last edited by jaw41272; 02-28-2008 at 04:21 PM.. Reason: spelling |
#9 |
Mirrors
Who needs mirrors.![]() Actually I tried a pair like shown above when I pulled my camper and they vibrated so bad I got dizzy looking in them and were no help at all and the factory mirrors get blown down by the wind so I jsut stop looking in my side mirrors. I live by my rear view mirror. ![]()
Blue 93' YJ, 4.0, 5spd, skyjacker 4" lift, crager simulated beadlocks w/33" bfg muds, skyjacker swaybar disco's, dana 30/35 w/ 4:10's, skyjacker t-case drop, and many mods to do yet Jeep Drivers who dig COUNTRY music member #13 |
#10 | |
but the cops get kinda cranky if you don't have 'em. JC Whitney sells relocation brackets, but I haven't tried 'em myself!
Where the black top ends, that's where the fun begins! |
#11 |
Have the same style as timatoe as far as location except mine the bolt the YJ hinge. Brand is CIPA and they were pretty bouncy and tended to move a bit. I added some neoprene washers to them and now they stay put and also don't bounce near as much, can actually use the drivers side. The passenger side is a bit harder to get used to and unless the windshield is clean it's almost useless. Were only 30 for the pair and a buck for the washers so was a cheap solution.
#12 |
I have ones that go in the upper door hinge
2003 WJ 4.0 - 2" BB - 255/75 on 17" JK Moabs - Projector's with 6000k HID's - 236k and counting 1996 XJ trail rig - sold "Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
#13 |
A couple of mirrors from checker, some flat stock i had laying around and a couple of bolts, nuts and washers....works great.
________________________________________ '94 4.0, AX-15 2.5" suspension lift, 1" shackle lift, K&N FIPK w/ AEM Dryflow, APN header, Smittybilt Front, Olympic Rear w/ carrier, Poison Spyder Corners Buffalo born and bred, now in CA. |
#14 |
so if you have relocation brackets that currently hold a standard YJ mirror can you swap in some CJ mirrors?
#15 |
I was told as long as you have a center mirror you are ok, it is either center or the two side mirrors. I ran doorless and without side mirrors all summer and I had no problem, even when I got pulled over once, they said nothing about the mirrors. I had the middle one on the windshield though. I dont know if I was just lucky or if it that is the NY law, as I only heard it second hand, not from a cop or anything, though I would be interested if anyone knows for sure.
[URL="http://groups.jeepforum.com/Square_Headlights"][I]Square Headlights[/I] - Founder[/URL] [URL="http://groups.jeepforum.com/Green_Jeep_Club"][I]New Green Jeep Club[/I] - Member #2[/URL] 1993 YJ Green/Spice - 6cyl 4.0L AX-15 2x KC Daylighters on windshield hinges, front hooks, rear shackle, 20' strap, shovel, saw, tools, air compressor, etc. -------- FOR SALE: - Set of 4 used 33x14.5r15 Mickey Thompson Baja Belted HP Tires on Alloy Rims (5 on 5.5 bolt pattern). - 2x white 6" KC Stone Guards (NEW) (PM me if interested) |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
