Side view mirror bracket opinions - JeepForum.com
post #1 of 15 Old 08-13-2011, 09:33 PM Thread Starter
bec
Just curious which relocation bracket seems to work well at a fair price?I finally pulled the doors off and would like a set of brackets. Thanks brian
bec is offline
post #2 of 15 Old 08-14-2011, 12:51 PM Thread Starter
bec
Anybody?
bec is offline
post #3 of 15 Old 08-14-2011, 01:14 PM
srdart67
I made my own and used an extra set of mirrors. They sit in the top door hinge. And only cost me about 60 bucks for the steel and the mirrors.
srdart67 is offline
post #4 of 15 Old 08-14-2011, 02:48 PM Thread Starter
bec
Thank you
bec is offline
post #5 of 15 Old 08-14-2011, 03:46 PM
mrmark
don't remember where I got them, I think quadratec
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
post #6 of 15 Old 08-14-2011, 04:22 PM
Spuznick242
How do those from quadratec work? I dont need the mirriors to be legal in PA but I like how those look. Do they just bolt over the stock hinges or do they replace the stock hinges? I like them because they look like it would be very easy to mount lights to.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #7 of 15 Old 08-14-2011, 08:41 PM Thread Starter
bec
Thanks for the pics.not illegal in al. But I find myself looking for them when I want to switch lanes.looks like alot to chose from online just wanted to get some that people have had good success with.thanks again
bec is offline
post #8 of 15 Old 08-15-2011, 04:12 AM
mrmark
They just use the same holes and go right over the windshield hinge. As far as seeing, the right side is hard to unless you use a mirror that sticks out further than stock, if use soft top upper doors forget seeing either at all.
mrmark is offline
post #9 of 15 Old 08-15-2011, 04:46 AM
wellsnmj
I don't remember who someone took a set of mirrors from a full size p/u from the JY and placed them in the top door opening with a nut seemed a pretty cheap fix
93 YJ SOA 4.0 Auto d30/d35 35" BFG KM 2 4 way disc brakes
08 MK stock
member of BJS x 2 !
My Build http://www.jeepforum.com/forum/f12/mean-jeep-build-1218336/
wellsnmj is offline
post #10 of 15 Old 08-15-2011, 07:02 PM
mrmark
might work, but what if, for some stupid reason, you want to put your doors back on?
mrmark is offline
post #11 of 15 Old 09-14-2011, 05:50 AM
wellsnmj
then I would say unscrew the nut remove mirror and re install doors
08 MK stock
member of BJS x 2 !
wellsnmj is offline
post #12 of 15 Old 09-14-2011, 06:54 AM
huntertim214
I picked these up from quadratec, only like $30. But...I could not, on my 94, get those little torx screws to come out...as with EVERYTHING I do on the jeep, it aint so easy!! I broke the head off the first one of course, the next one just stripped out my bit....and I then I gave up. (and these had been treated with PB Blaster for a few days before hand, which is standard practice on everything for the old girl...) So I just went with the old "look over your shoulder" method all summer. I decided I'd go with motorcycle mirrors like a lot of guys do, just haven't done it yet, or the Dual Soft Door Mirror Sets from quadratec.
huntertim214 is offline
post #13 of 15 Old 09-14-2011, 08:13 AM
mfalik
mfalik's Avatar
I had a set of these. They are mounted using the lower bolts of the windshield hinge, which are semi-easy to remove (and reinstall).
The brackets seemed to be of poor quality. The powder coating peeled off after 3-4 years, and brackets because pretty rusty.
If you want to have mirrors for when you take the doors off, here are some other options.
http://www.jeepforum.com/forum/f176/...rrors-1050836/
http://www.4x4xplor.com/doorless-mirror.html
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
post #14 of 15 Old 09-14-2011, 09:40 AM
jmmorgan82
2009 JK Wrangler
I went the permanent route with CJ mirrors I found off of eBay.
jmmorgan82 is offline
post #15 of 15 Old 09-14-2011, 09:44 AM
vadslram
I have a set of those from Quadra. They work well with one major flaw. If you try to use any regular mirror and have any doors including soft doors you will be constantly having to re-adjust your mirrors. They sit at just the right level that when the door opens it hits the mirror. When I switch between hard top/doors and the soft top/doors I don't want to keep switching mirrors too.
I just ended up ignoring the passenger side and rely on the rear view and the drivers side.
I'm planning a light bar and I want to mount the mirror high enough to clear the door when it opens yet still have a decent field of view. If I ever get it done I'll post pics.
vadslram is offline
What I did for a side-view mirror jmmorgan82 YJ Wrangler Technical Forum 3 01-07-2011 09:55 PM
Side View Mirror Water MX355 JK Wrangler Technical Forum 9 05-31-2009 04:25 PM
Side view mirror with soft doors... bjjfoshizzy TJ Wrangler Technical Forum 12 10-29-2008 08:53 PM
NJ Side View Mirror Law? xwejx JK Wrangler Technical Forum 4 09-02-2007 05:10 PM
Side View MIrror MOunting Bracket. Euclid34 TJ Wrangler Technical Forum 4 05-13-2005 10:15 AM
