Sick Of Being Cold!!!!!!!!! - JeepForum.com
post #1 of 23 Old 01-29-2010, 06:49 PM Thread Starter
WSTOF7
ok i have a 92 jeep yj 2.5 its my dd the heat barely works in it it has a new water pump and i high temp thermostat im thinking about replacing the heater core etc with replacement stock parts but first i want to know how well the stock heating system in these things works in perfect operating condition and if theres any modifications i can do to make it work better or an aftermarket heater or something that would give me better heat all i can find is a blazer heater motor swap but apparently thats onlyt for 91s and under i drive it in temps of up to -50 and it just sucks any info would be greatly appreciated and any tips for keeping warm in a yj would be greatly appreciated too
WSTOF7 is offline
post #2 of 23 Old 01-29-2010, 07:25 PM
timatoe
timatoe's Avatar
The stock heating system is very effective. I'd suggest you pull the hoses going to the core and flush the system first.
The "Blazer" upgrade, may not have any affect on your system, because at some time in '92 (I believe) they went to the bigger motor stock. The Blazer motor and the YJ replacement motor are one in the same PM-102.
Here's bunch of good stuff about heater systems from the FAQ..... http://www.jeepforum.com/forum/f12/y...6/#post8107902
timatoe is online now
post #3 of 23 Old 01-29-2010, 07:29 PM
PrinothPro
Check your cable. I brought new blower upgrade, new tstat, radiator, heater core and even water pump before I discovered the cable that control the heat was binding real bad. I fixed that and the heat blows real hot like it never has in years. I didn't even need to buy all of that parts. At least I have those parts ready to go in case any of those parts croaked.
Just check everything and fixing heater is really easy, just pain in the *** to remove and put it back together.
PrinothPro is offline
post #4 of 23 Old 01-29-2010, 07:30 PM Thread Starter
WSTOF7
could i just shove the end of a pressure washer in the hose that leads to it or would that be too much? how do itell if i have the good heater motor? apparently its an early build 92. cant find this anywhere else on the forum
WSTOF7 is offline
post #5 of 23 Old 01-29-2010, 07:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Blend door in full COLD position.
Blend door in full HOT position.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 23 Old 01-29-2010, 07:32 PM Thread Starter
WSTOF7
like the cable that hooks to that loop under the dash?
WSTOF7 is offline
post #7 of 23 Old 01-29-2010, 07:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, it runs the blend door.
Max
Mean Max is offline
post #8 of 23 Old 01-29-2010, 07:34 PM Thread Starter
WSTOF7
cables works fine
WSTOF7 is offline
post #9 of 23 Old 01-29-2010, 07:35 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Here's a blend door pic I stole from another thread!
http://www.jeepforum.com/forum/f12/heater-core-219329/
Max
Mean Max is offline
post #10 of 23 Old 01-29-2010, 07:39 PM Thread Starter
WSTOF7
so can i just disconnect the heater hoses and flush it out with a pressure washer?
WSTOF7 is offline
post #11 of 23 Old 01-29-2010, 07:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I wouldn't use any kind of pressure beyond garden hose pressure if it were me.
Max
Mean Max is offline
post #12 of 23 Old 01-29-2010, 08:13 PM
timatoe
timatoe's Avatar
Max
X's2, I'm pretty sure if you use a pressure washer, you WILL be replacing the core.
post #13 of 23 Old 01-29-2010, 08:35 PM
MJMPC
At -50 I dont think any STOCK jeep will kep you warm.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #14 of 23 Old 01-29-2010, 08:40 PM Thread Starter
WSTOF7
flushed the heater core slight improvement but it still sucks how do i find out if i have the good heater motor? i was thinking about getting one of those auxiliary heaters from canadian tire and mounting it between the seats does anybody have any ideas?
WSTOF7 is offline
post #15 of 23 Old 01-29-2010, 08:46 PM Thread Starter
WSTOF7
they look like the heaters in a school bus run off engine coolant
WSTOF7 is offline
Cold, cold, cold air blowing when the heat is on fstfl YJ Wrangler Technical Forum 9 12-02-2010 01:08 PM
Cold Start New to Cold Weather Thexonexkid TJ Wrangler Technical Forum 18 12-02-2009 01:39 PM
Help, getting sea sick Existence JK Wrangler Technical Forum 8 12-01-2009 11:21 PM
Sick TJ THEKEEB17 TJ Wrangler Technical Forum 13 04-05-2005 10:22 PM
sick little 2.5L nsi31 TJ Wrangler Technical Forum 12 05-18-2004 08:49 PM
