SI alternator to CS144 - JeepForum.com
post #1 of 2 Old 06-18-2012, 12:49 PM Thread Starter
spawnofsatan
Hey guys do I need to solder a resistor to install my cs144 on my 90 YJ or can I just order this from NAPA Part Number: ECH EC82 and just plug it straight to the alternator.
spawnofsatan is offline
post #2 of 2 Old 06-18-2012, 01:23 PM
jbolty
jbolty's Avatar
If you have a 1990 4.2 then it's a pretty simple hookup. I did not have to do anything other than wire the plug into the harness. As I recall there is some mod you can do with a resistor in order to swap a delcon style alternator into a 1991 or later.
jbolty is offline
Delco CS144 doherty80 YJ Wrangler Technical Forum 8 03-31-2011 10:48 PM
Bad alternator? CoHaley TJ Wrangler Technical Forum 13 01-29-2011 09:05 PM
CS144 Alternator Identification Douglas S. YJ Wrangler Technical Forum 7 03-02-2010 07:09 PM
Delco CS144 Series alternator doherty80 YJ Wrangler Technical Forum 26 08-21-2009 10:02 PM
Another Alternator???????????? 94stock YJ Wrangler Technical Forum 2 06-12-2009 02:31 AM
