shuddering AX-15 tranny - JeepForum.com
post #1 of 9 Old 10-26-2001, 03:56 AM Thread Starter
evilpsych
evilpsych's Avatar
ok.. just noticed this today.. while driving.. a high pitched metal on metal sounding noise when i'm going between 15-40 mph.. it's only when the engine is under heavy load, it's not RPM dependent, so i'm guessing it's between the tranny output shaft and the rear end.. also. the tranny shudders a little bit between 2-4th gears.. is it time for a new tranny? a clutch? i'm hoping it can be solved with a gear oil change (dont think it's ever been done on the vehicle) and maybe a tranny mount replacement or U-joint.. *sigh* i just hope it's something simple and doesnt required a new tranny or transfer case..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 9 Old 06-15-2011, 11:55 PM
johnnykind
did you ever figure it out im having the same problem, ???
johnnykind is offline
post #3 of 9 Old 06-16-2011, 12:01 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Holy thread resurrection Batman!
What the OP described sounds like a slipping clutch.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 9 Old 06-16-2011, 12:13 AM
jhumphrey
Is that the metal on metal sound under load or shuddering? Mine shudders from time to time, I had the oil changed in it and its done it once or twice since.
I was on the trail the other day when something odd happened to me. I was in 1st with 4lo engaged. I had my foot with the clutch pushed "in" and started to slowly let out, but the jeep didnt move. The shifter was humming and sort of made a grinding sound. I put the clutch back "in" (toward the firewall), shifted the trans back into N, then back into 1st. The jeep than took off.
Does that mean my clutch is going out? Syncro gears? Transfer case?
jhumphrey is offline
post #5 of 9 Old 06-16-2011, 12:29 AM
moonshinefuel
2001 lol,
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #6 of 9 Old 06-16-2011, 06:52 AM
alfredrich
Just try once to resolve this problem by changing the engine oil, to the best of the knowledge the shuddering of the tranny can be solved by doing that. Even then if the problem persists then consult a dealer.
alfredrich is offline
post #7 of 9 Old 06-17-2011, 12:04 AM
Opihi59
Opihi59's Avatar
Hard to tell. It is possible you weren't totally in gear, or your T case wasn't fully engaged and it was slipping, like the T case linkage was out of adjustment a bit. Depends a lot on whether or not your problem is reproducable over time, but I can't narrow it down much.
Opihi59 is offline
post #8 of 9 Old 06-17-2011, 12:29 AM
jhumphrey
I'll keep an eye out and report back if/when it happens again. I've had the jeep since late Jan and its done that twice since Ive had it. The first time, I backed up into my buddies driveway to drop off some stuff. I left the jeep running, trans was in neutral and tcase was in (2HI). When I got ready to leave, I couldnt get the jeep to go into first. There was just a humming noise and some grinding. I than put the jeep in reverse (it went in fine), backed up a little, then shifted into first and it went without any trouble.
Thats when I decided to take it to the tranny shop for a fluid change, which they did. They said everything looked fine, then this thing happened on the trail. Could just be things "not meshing up" properly from time to time (as circumstances would have it). I just want to make sure my tranny isnt about to drop....
post #9 of 9 Old 07-14-2011, 04:07 PM
jhumphrey
Ok all, so I changed my trans mount, which was shot. We'll see if it takes care of the "humming" gear issue.
After the replacement, I drove for about 10 miles in medium traffic (stop and go). Ive noticed that on slower speed takeoff (if I give it some gas, its fine, if its a "lower RPMs" it seems to do it more), the jeep will shudder and "buck" violently. It only last for a few seconds and then its fine again. Its always right at takeoff. Its not every takeoff, but at least once or twice while Im out.
My jeep has about a 3" body lift on it from a PO. Do I need to do a tcase drop to see if that fixes the shudder problem?
Jeep is shuddering...? HMTwin TJ Wrangler Technical Forum 4 11-21-2009 06:11 PM
tranny shuddering?? Beltfed09 JK Wrangler Technical Forum 9 08-28-2009 11:46 PM
Bogging/Shuddering in 4th, 5th, 6th any RPM Jordon83 JK Wrangler Technical Forum 4 07-07-2009 10:40 AM
Need some help (shuddering) BlackJeepin TJ Wrangler Technical Forum 11 06-03-2008 06:39 PM
Shuddering on takeoff... RenegadeYJ17 YJ Wrangler Technical Forum 3 04-13-2003 11:07 PM
