Show me your...Power distibution, relays, and fuses - JeepForum.com
post #1 of 17 Old 06-30-2011, 05:01 PM Thread Starter
imstillatwork
Let's see your add-on wiring setups!!
I'm going to be wiring up front flood/fog lights, auxiliary backup light, inverter, full interior lighting, and an electric fan, cd player (no amp). (more stuff later)
I want to wire it up RIGHT with a fuse panel, relay panel and a nice power distribution block. I want to get all the extra wires running from the battery onto a PDC.
I can find lot's of audio stuff, but not what I'm looking for.
Show me yours so I can build mine
imstillatwork is offline
post #2 of 17 Old 06-30-2011, 05:13 PM Thread Starter
imstillatwork
Looking for a supplier for these, looks pretty good, but maybe too bulky for my needs
http://www.littelfuse.com/commercial...tribution.html
post #3 of 17 Old 06-30-2011, 05:39 PM
timatoe
timatoe's Avatar
West Marine has a nice fuse panel. I got a much cheaper panel from Foothill Offroad and then mounted it and the relays to a plate that is then mounted to the bracket that used to hold the stock jack. Not the prettiest but it works. There was also a thread on here a couple of days ago about using late model GM boxes.
Here's an old pic of mine...
timatoe is offline
post #4 of 17 Old 06-30-2011, 05:42 PM Thread Starter
imstillatwork
Cool, I'll check it out. I like the pre-wired relay blocks I see everywhere, but there is no way to mount them without using the relay tab. I was hoping to find a 4 or 6 position relay block (for cheap, of course)
post #5 of 17 Old 06-30-2011, 05:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I was hoping to get some better ideas for electrical management from this thread. I picked up a PDC from a neon as per a junkyard thread recommendation I just haven't implemented it yet. Anyone have a writeup on them? The wires are everywhere and kinda confusing me. I'm sure the OP would find it useful as well.
Sorry for the hijack!
Anticanman is offline
post #6 of 17 Old 06-30-2011, 06:17 PM
CT-Rich
I built a custom box for mine
'95 YJ 2.5l, R.E. Extreme 2.5" lift, MT Baja MTZ 31x10.5x15
CT-Rich is offline
post #7 of 17 Old 06-30-2011, 06:25 PM Thread Starter
imstillatwork
Nice!
post #8 of 17 Old 06-30-2011, 10:40 PM Thread Starter
imstillatwork
I got one of these
These switches
Some relays. Need to grab some wire, terminals, shrink tube locally. Going to check the hardware store for a small plastic utility box to put it all in.
Still wanna see more installs!
For the fan and interior lights I got a on-off-on switch: tempswitch-off-on for the fan, door-off-on for the the interior lights.
post #9 of 17 Old 07-01-2011, 09:13 AM
JWBooth
CT-Rich, brother, that box and panel set up is SICK!!!!!! Well done.
Please Note: My actual location is a lead box in Sassafras Cove.
-Proud Co-Founding Member of the Dirtbag Brotherhood
-Ringleader of the WhiteTrash Circus.
**LONG LIVE 4-LOW**LONG LIVE 4-LOW**LONG LIVE 4-LOW**
JWBooth is offline
post #10 of 17 Old 07-01-2011, 11:33 AM Thread Starter
imstillatwork
Awesome, looks great!
post #11 of 17 Old 07-01-2011, 06:31 PM
littleredjeep
CT-Rich that is pretty cool looking. I am going to be keeping a eye on this thread.
88 YJ 4.2, 5-speed, 4"RC lift, 5/8 booms, herced tub, and cavi seats
My build thread
_____
/| ,[___],
|--L --[]lllll[]-
()_) ()_)-o-)_)
littleredjeep is offline
post #12 of 17 Old 07-01-2011, 06:47 PM
CT-Rich
Thanks guys
I'm happy to provide any details, diagrams, part numbers, more pictures that anyone wants
CT-Rich is offline
post #13 of 17 Old 07-01-2011, 06:55 PM
Boodyrider
Use an extra stock PDC from a TJ, Cherokee, or similar. Buy the tool that allows you to remove and insert terminals.
But CT-Rich... that is beautiful work. How about you do a build thread on that mod there, with pics, part numbers, and estimated costs?
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #14 of 17 Old 07-02-2011, 01:56 AM
92 Green YJ
92 Green YJ's Avatar
ok. I'll play.
Blue Seas 12 circuit fuse block with ground terminals. Mounted on firewall above the battery tray. Wired to the battery with some leftover 4 gauge amp power cable I had floating around.
Dont seam to have a pic, but I mounted a piece of 1"x1" box tube across the firewall as well that I have all my relays mounted to.
then there is my home made aluminum switch panel. Every accessory has a relay and a fuse. I used cat6 cable from the switch panel to each relay since the activation side of the relay takes next to no juice to activate and it let me just run one nice clean cable from the panel to the relay bank. each switch has an LED to indicate power on. the gauge is for my on board air
2 switches dont do anything at the moment (the 2 at the right side) but they are all wired up to fuses and relays for when i decide to add something else. first 2 switches are for an in cab winch control. left is to arm it, the right is straight off a spare warn winch controller, even trimed the plate for the in and out graphics
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #15 of 17 Old 07-02-2011, 03:01 PM Thread Starter
imstillatwork
Originally Posted by 92 Green YJ View Post
ok. I'll play.
sweet
ecu, fuel relays and fuses ohh my! drumsaregood46 YJ Wrangler Technical Forum 2 09-23-2008 08:53 PM
ABS Fuses and Relays. Punko TJ Wrangler Technical Forum 3 03-19-2008 08:33 PM
power distribution relays and fuses Natedogg0669 YJ Wrangler Technical Forum 6 04-10-2007 06:41 AM
TJ PDC PLease explain relays & fuses Deki TJ Wrangler Technical Forum 6 03-22-2007 11:14 PM
Fuses And Relays 2001 BEANS TJ Wrangler Technical Forum 2 01-10-2006 03:52 PM
