Should the starter work when.... - JeepForum.com
post #1 of 2 Old 03-31-2007, 09:41 PM Thread Starter
daaaaaan
Should the starter work when you connect the positive wire and short wire on the starter via a Jump Lead...? I am trying to diagnose my starting issues....which is nothing happens when I turn the key....(but I am able to push and pop the clutch to start it)
2012 Overland 5.7L
daaaaaan is offline
post #2 of 2 Old 03-31-2007, 10:43 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
when you short the positive on the solenoid to the positive on the starter, yes it should turn over...
disconnect the ignition first though, or make sure the key is off....
safer to disconnect the ignition imo, safety first!
if that doesnt make the starter turn over, then the starter is fried...or the starter wires going to the battery
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
XJ starter work in a TJ? mike68 TJ Wrangler Technical Forum 9 04-21-2009 02:07 PM
will starter for a 4 cyl. work/fit in a 6 cyl.? peebody YJ Wrangler Technical Forum 4 03-03-2009 07:22 PM
Will a TJ starter work? BudmanV6 YJ Wrangler Technical Forum 1 04-19-2006 07:31 PM
How do you get the Starter to work without pressing the clutch? rshrimp TJ Wrangler Technical Forum 38 01-31-2004 11:00 PM
