should i or should i not - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > should i or should i not
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 03-26-2014, 08:15 PM   #1
abbott407
ok my jeep has a 4 in suspention lift pro comp the PO that had it b4 me took out some leafs to make it ride better i am now noticing that the leafs are wearing some so should i put the leafs back in that they took out or should i just leave it alone they r not bad still have arch to them i dont care bout the smoothness of the ride its a yj
abbott407 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 08:27 PM   #2
superj
1987 YJ Wrangler
Its your call
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 03-26-2014, 11:24 PM   #3
DirtKar
I pledge allegiance.
DirtKar's Avatar
Ok my my jeep has a 4 inch suspention lift that i put in to replace the junk that the PO put in and it rides real nice not like a yj on a junky pieced together setup like it had b4 but real smooth like I would expect from something built proper like I've done from the lessons i learned here on the forum cuz i do care like the guy before me said its ur call if you want it to ride nice jus sayin it doesn't have to ride harsh im not sure of the damage to ur springs so its hard to say if putting them back will help i think it will get worse/stiffer but u said you don't care.
Welcome to the forum, Abbott. Tons of info on here to help you decide how to proceed with your build.
What you see as not bad, and what I see as not bad, are two completely different not bads
YJOTM JULY 2014
DirtKar is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 01:10 AM   #4
abbott407
thanks for the reply and yes i know it will be stiffer just tryin to save what i have
Unread 03-27-2014, 01:34 AM   #5
abbott407
the pro comps are really stiff
Unread 03-27-2014, 03:31 AM   #6
abbott407
where they took some out i guess what im sayin is that it has too much flex 4 me
Unread 03-27-2014, 03:35 AM   #7
Anticanman
Follow me
Anticanman's Avatar
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 10:29 AM   #8
jaycal3
Ouch, my head hurts now... Abbott407 welcome to the forum. Please try to put some punctuation in your threads... a period or comma would break up the monotony...
Regarding your springs, it wouldnt hurt to sdd the leafs... but then if you dont really care about the ride whats the point. As you say, you "dont care bout the smoothness of the ride its a yj"...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms
Do your part for Leukemia research - help find a cure.
http://mskcc.convio.net/goto/Jay_Calabrese
KCCO
jaycal3 is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 07:03 PM   #9
abbott407
ok thanks for the reply i may just leave them out. And let them wear out and put new ones under it.i do care bout the ride but either way i know it will still be bouncy. thats what i was refurring too. i have learned alot from these forums. dos and donts what would be some good recommendations for springs. it is my DD but i do take it off road some. nothing extreme though.
Unread 03-27-2014, 08:37 PM   #10
whiskeywiz
I was kinda diggin' it! Nice and fluid. Good flow. Do your thang, abbott407!
whiskeywiz is offline   Reply With Quote Quick reply to this message
Unread 03-27-2014, 11:05 PM   #11
Dwarf
1987 YJ Wrangler
Yeah - who made you the grammar queen, jaycal?
Dwarf is offline   Reply With Quote Quick reply to this message
Unread 03-28-2014, 07:04 AM   #12
jaycal3
Simmer down dwarf... It was about punctuation not grammar, and I answered his question... A little constructive criticism never hurt anyone.
Sent from my iPhone using JeepForum... So excuse the typos, my iPhone is challenged.
KCCO
Unread 03-28-2014, 07:52 AM   #13
Rproject
Rproject's Avatar
1987 YJ Wrangler
A YJ doesn't have to be a bucky horse of a ride.
Save up your money, let your existing springs die, then get a good set of RE, Zone, BDS or OME springs with quality shocks. When you're done, it'll feel like a completely different vehicle.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote Quick reply to this message
