short vs long crank snout - JeepForum.com
post #1 of 4 Old 03-30-2010, 06:44 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
87 Wrangler 4.2L uses v-belts
So with my re-man engine I got a short crank snout. I had a long crank snout on the original. I know the woodruff key is different and when I look at the harmonic ballancer I see that the balancer wont have the crank stick all the way thru. The crank on the engine has about an inch for the harmonic balancer. The HB has an inch and 3/4 depth to it. Am I ok with it the way it is.. Are there other balancers out there.
wanabejeeper is offline
post #2 of 4 Old 03-30-2010, 07:47 PM
ctm
I have only ever seen one part number for the balancers, most suppliers list one for years 72-90, but you are right there are different keys; and there are different bolts, one is shorter than the other. Just make sure the bolt you use does not bottom out in the crank before it pulls the balancer all the way on . It's possible you may need a slightly different thickness of the washer for the bolt.
ctm is offline
post #3 of 4 Old 04-01-2010, 12:08 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
Does anyone have the specs on the longer bolt?
edit, NM i spent some time measuring.. The HB with the fat washer is 2" thick based on a fully seated HB that means I need an additional 3/8 to 5/8" longer bolt. The current bolt would actually work but I would only have about 1/4 inch seated into the crank of a max of 3/4...
post #4 of 4 Old 04-05-2010, 04:57 PM
ctm
the two length specs in the parts list are 1.25" and 1.62"; but this doesn't matter too much, all you need to do if get enough engagement without bottoming out.
ctm is offline
the long and the short Vacant Stare TJ Wrangler Technical Forum 1 12-08-2007 09:11 AM
long arm vs short arm hiram TJ Wrangler Technical Forum 6 07-15-2007 06:13 PM
Long Arm vs. Short P89Jeeper TJ Wrangler Technical Forum 3 11-01-2006 04:41 PM
Long Arm - Short Story - Short Arm... folkxrock TJ Wrangler Technical Forum 24 08-12-2006 06:23 AM
Short Arm vs Long Arm willwheel4food TJ Wrangler Technical Forum 6 03-19-2006 09:28 AM
