Shocks for OME lift - JeepForum.com
post #1 of 6 Old 08-27-2011, 11:14 PM Thread Starter
sbs1794
Shocks for OME lift
was wondering what shocks (other than OME, $$$), would fit a 2.5 OME lift with 5/8 inch shackles. Rancho 5000 series? seems a little short to me but would it fit? How about skyjacker there extended length is 4 inches longer than OME shocks, so they should fit, right? Any others?
sbs1794 is offline
post #2 of 6 Old 08-27-2011, 11:27 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
First off Welcome to JeepForum, Please fill out your vehicle specs . It will help us help you out !
If you have OME Springs dont degrade them with Rancho's stiff *** shocks Your ride quality will suffer !
You bought the OME springs for Ride quality and Flexability dont be cheap and fork out the extra $ for some Bilestein 5100's , or OME's One reason high end shocks have a hefty price is because they are usually specfically valved for you vehicle and not a genetic one shock fits all valving.
Here's the specs for the Bilstein 5100 for your application :
46mm Monotube Shock Absorber
New Part Number: 24-064576
Old Part Number: F4-BE5-6457-H5
Setting: 5100 Series
Drive Type: 4WD
Position: Front
Descriptor: Front Lifted Height: 3-4"
*Collapsed Length (IN): 16.97
*Extended Length (IN): 28.44
*Collapsed Length (MM): 431.0
*Extended Length (MM): 722.5
Finish: Zinc plated
Reservoir: No
Part Number: 24-185660
Old Part Number: F4-BE5-6458-H5;F4-BE5-6458-H7
Drive Type: 4WD
Position: Rear
Descriptor: Rear Lifted Height: 3-4"
*Collapsed Length (IN): 14.63
*Extended Length (IN): 23.68
*Collapsed Length (MM): 371.5
*Extended Length (MM): 601.5
You can take the Extended and Collapsed length of these shocks and find other shocks the same length also.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 6 Old 08-28-2011, 09:43 AM Thread Starter
sbs1794
What about rubicon twin tube?
sbs1794 is offline
post #4 of 6 Old 08-28-2011, 12:01 PM
c_coops
I can't vouch for their twin tubes, but I can say from first hand experience that the RE monotubes are awesome. They're firm but not harsh at all.
c_coops is offline
post #5 of 6 Old 12-17-2011, 11:42 PM
BIGJoe29
Drive Type: 4WD
Position: Front
Finish: Zinc plated
Reservoir: No
Drive Type: 4WD
Position: Rear
i unfortunately got a rough country 2.5in lift(my dad was steadfast on buying the cheapest kit) will these bilsteins be too long because i want to improve my YJ's ride and drive it on dirt roads going at a decent speed and not urgently need to see a chiropractor right after haha.
if they dont fit, what other monotubes do you recommend that will fit for around the same price(under $90 each
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #6 of 6 Old 12-18-2011, 01:56 AM
jhumphrey
How about Rancho 9000's? Ive read good things about them and plan on putting them on when I put my OME 2.5 lift on....
jhumphrey is offline
2.5 , lift , old man emu , ome , shocks
will Rancho RS9000 (5-6in lift) shocks work with a Rough Country (4in lift) kit? Arron TJ Wrangler Technical Forum 1 04-02-2011 01:12 PM
Do I need a lift kit to lift my Jeep 3" or only shocks will do? Mitch72 TJ Wrangler Technical Forum 22 05-29-2010 11:53 AM
best shocks for 4inch lift, 1 inch body lift epeck87 TJ Wrangler Technical Forum 0 04-05-2009 01:49 PM
2 inch lift - Shocks or no shocks?? BuzzHog JK Wrangler Technical Forum 5 03-25-2008 03:58 PM
3.5" lift shocks with out lift ? terrible TJ Wrangler Technical Forum 3 07-08-2005 10:05 AM
