Shocks? -
post #1 of 4 Old 03-04-2013, 12:36 PM Thread Starter
Hi! All Can I use Pro Comp shock #32050 Explorer's on teh front of my Jeep and # 32950 on the back of my Jeep???? Can't find any Info on these at there site. My son had these for his Chevy truck and never used them was wondering if I can put them on my wrangler YJ 1989. I would like to use them. thanks Joe100
Joe100 is offline
post #2 of 4 Old 03-04-2013, 12:47 PM
Measure the extended and collapsed lengths of the shocks and of the Jeep and youll have the answer
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 4 Old 03-04-2013, 12:47 PM
do both upper and lower shock mounts match? (eye or stud) if so, you're half-way there.
the only way to know for sure would be to measure your full travel... remove your YJs shocks and cycle the suspension from full compression to full droop... compare that measurement to the collapsed and extended measurement of the shocks
simplest way to compress/droop the suspension would be to find a ramp somewhere... or if you've got a buddy with a forklift, you can do it that way too.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 4 Old 03-04-2013, 12:57 PM
RIP one good jeeper
Anticanman's Avatar
^^^What they said ^^^
Luck Favours The Prepared
Anticanman is offline
In order to be able to post messages on the forums, you must first register.
