shocks ??? - JeepForum.com
post #1 of 9 Old 09-14-2011, 08:44 PM Thread Starter
hnda88
shocks ???
i recently lifted my 95 wrangler with a 4'' inch lift. when i put the shocks on that came with the kit they were very close to being all the way extended. does this mean that there will be no travel for articulation and the shocks will hold my wheels up?
hnda88 is offline
post #2 of 9 Old 09-14-2011, 08:50 PM
Ripper3494
what brand of lift did you get and were you installing the shocks with the weight of the jeep on its tires or no?
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 9 Old 09-14-2011, 08:55 PM Thread Starter
hnda88
i got the rough country 4'' inch lift with n2.0 shocks and i installed the shocks when my jeep was on my lift. but when i put my jeep on the ground, it did not drop very much. i see that you have a yj to and do you run your sway bars and track bars because im thinking about taking mine out.
hnda88 is offline
post #4 of 9 Old 09-14-2011, 09:06 PM
Ripper3494
those shocks are correct, i actually just bought a set of em lol, i took out my rear trackbar, and the front swaybars. i had the front trackbar out for a little while and didn't like the way it drove, it had too much back and forth motion when i turned. im thinking about putting a rear trackbar back in though because with the v8 there's probably gonna be some sideways stuff happening
build thread:
RC vs BDS
post #5 of 9 Old 09-14-2011, 09:07 PM
Ripper3494
but for a moderate build, take the rear trackbar out and either remove the swaybars or make quick disconnects
build thread:
RC vs BDS
post #6 of 9 Old 09-14-2011, 09:13 PM Thread Starter
hnda88
but will the shocks stop me from articulating when i remove all the bars?
hnda88 is offline
post #7 of 9 Old 09-14-2011, 09:16 PM
Ripper3494
they shouldn't, the shocks are designed to be the correct length to give you full droop of your suspension without damaging anything. id say flex it up on a rock or something and see how it does, if it looks like its being limited too much call or email RC and see what you can do about it
build thread:
RC vs BDS
post #8 of 9 Old 09-14-2011, 09:18 PM Thread Starter
hnda88
ok thanks
hnda88 is offline
post #9 of 9 Old 09-14-2011, 10:01 PM
jeepnbrett
Jack up the Jeep and support it from the frame on jackstands. Unbolt the shocks while in the air. If the suspension droops after unbolting the shocks then you need longer shocks.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
Doetsch Shocks Dt 3000 And Rusty's Performace Shocks SOLIDJP44 TJ Wrangler Technical Forum 0 04-05-2009 01:40 PM
Stock shocks vs teraflex 9550 shocks? Dhall09 JK Wrangler Technical Forum 6 02-23-2009 09:27 AM
terra 2.5bb shocks vs rubi stock shocks TrickyDogShow JK Wrangler Technical Forum 1 08-26-2007 05:02 PM
Skyjacker Hydro Shocks vs Rubicon Express Twin Tube Shocks jbpdog TJ Wrangler Technical Forum 8 06-13-2006 09:52 PM
Rubicon Express RE Monotube Shocks or OME Shocks on 33's / RE4.5sf TJ Wolf TJ Wrangler Technical Forum 3 05-11-2005 12:23 AM
