shock replacement - JeepForum.com
post #1 of 3 Old 10-10-2008, 08:36 AM Thread Starter
jgillespie
shock replacement
i plan to replace my stock shocks soon. quadratec has any and every kind imaginable. i am seeing lots of items with "eye to eye" lengths. what would be the right length for stock?
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #2 of 3 Old 10-10-2008, 08:40 AM
Brandon_YJ
1987 YJ Wrangler
Start here:
http://www.quadratec.com/advisor/jee...rangler&lift=0
All shocks for 91 Wrangler with no lift
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 3 Old 10-10-2008, 09:11 AM
Jim93YJ
Jim93YJ's Avatar
And here as well:
http://www.jeepforum.com/forum/showt...t=shock+length
JeeperDon has good advice on determining correct size of shock you will need.
93YJ 4.8L Vortec,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 33" BFG KM2 T/A's with MT Classic II Wheels, Herculined Inside, Electric Fan, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bushwacker Extended Flat Fender Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline
shock replacement 91jeep4sb YJ Wrangler Technical Forum 10 01-26-2009 06:58 PM
shock replacement DVS TJ TJ Wrangler Technical Forum 1 05-10-2006 05:13 PM
Shock Replacement lizdog TJ Wrangler Technical Forum 3 08-03-2005 10:55 PM
Shock Replacement..HELP!! JasonBeaulieu TJ Wrangler Technical Forum 4 06-08-2005 02:22 PM
Shock Replacement... Jepetto21 YJ Wrangler Technical Forum 0 06-05-2005 10:32 PM
