Shock Question - JeepForum.com
post #1 of 10 Old 10-10-2002, 09:41 AM Thread Starter
bigjeep39
bigjeep39's Avatar
Shock Question
Does anyone know why the flip their shocks, or rotate them. like in this picture??
shawn
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 10 Old 10-10-2002, 07:09 PM
monkeywrench
shocks
in the rear my shocs hit the axle when the suspention flexes turnes them upside down the chrome rod clears the sxle fine
in the front at full stuff in the fender my brake caliper bolts hit and dent my shocks
any one els have this problem rs 9000 4 1/2 RE LIFT LOVE IT NO BUMP STOPE EITHER
jamie 92 yj 4 1/2 RE extream duty 2 body 35-12.50-15 4.56 arb frt rr yorkair warn 9000 zenon flares tomken tire rack 4.0 borla header magnaflow exhaust flexes awsome CURRIE 9INCH HIGH PINION IN THE REAR WITH DISC BRAKES ITS SHAVED TO just added TERA LOW 4 TO 1 TRANSFER CASE KIT
monkeywrench is offline
post #3 of 10 Old 10-10-2002, 07:25 PM
93jeepyj2.5
93jeepyj2.5's Avatar
MonkeyWrench,
Got any pics of your Jeep?
-Heath
93 Black YJ, locked and on 33's----Sold
03 TJ Sport.....31" MT/R's on MT Classic II's
93jeepyj2.5 is offline
post #4 of 10 Old 10-11-2002, 04:27 AM Thread Starter
bigjeep39
bigjeep39's Avatar
no offense, and not to be rude, but that has nothing to do with my post, please stick to the post of why do they flip them like that??
shawn
1998 TJ
post #5 of 10 Old 10-11-2002, 08:05 AM
St.LJustin
St.LJustin's Avatar
Yeah, most shocks are to wide to mount upright on the rear axle due to what monkeywrench said. One thing to look for is that the shocks can be mounted upside down according the manufacturer. My Doetch (sp) shocks that can with the RE lift were made to be mounted either way and they don't hit anywhere.
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #6 of 10 Old 10-11-2002, 09:00 AM
K&L
As for mounting them upside down, when I was working on late model race cars, there was rumor that mounting them upside down would change the compression/rebound rate. Several racers started it and a lot of others followed. My though was it might change it slightly as the main valves would no longer be in oil but in the gas as the oil moved down to the bottom half (actually the top)of the shock. BUT I have not read any manufacturer info stating that this was true.
Kevin
87 YJ, 4.2L w/ Nutter , 5sp, 1'body lift
31X10.50 BFG AT'
K&L is offline
post #7 of 10 Old 10-11-2002, 11:19 AM
St.LJustin
St.LJustin's Avatar
Like I said, a lot of the newer shocks have the ability to be mounted either way becaus they have been made to be correctly oiled either right-side up or upside down.
post #8 of 10 Old 10-11-2002, 12:07 PM Thread Starter
bigjeep39
bigjeep39's Avatar
did you all look at the pic, i mean mine are mounted up right (normal) and work fine.. i didnt know if it was better to do it there way??
I need new shocks b/c the ones i have right now hinder my flex, i dont know where to buy long travel??
shawn
1998 TJ
post #9 of 10 Old 10-11-2002, 12:15 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Looking at the picture that you show in your link above, I wouldn't be able to comment on the reason why he did it personally.
Hey might have made himself a set of shock-hoops, or needed to lower his shock-mounts, or .. any one of a dozen reasons.
Generally, I would go with what K&L suggested .. it was done by race cars owners for a different shock feel ..
And Shawn .. take your shocks off, flex your beast till it can't go anymore, then measure your compressed side and your extended side. Use those measurements to contact Rancho (or any shock manufacturer you desire) through their webpage and just order it. There is always the ability to check with your local 4x4 shop as well, as they normally carry a wide range of shock sizes for just about every lift kit on the market.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #10 of 10 Old 10-11-2002, 12:28 PM Thread Starter
bigjeep39
bigjeep39's Avatar
ya, i just saw the shox upside down... looked cool, i will have to try the flex idea!!!
thank you,
shawn
1998 TJ
shock question Zorm YJ Wrangler Technical Forum 3 08-21-2008 08:46 PM
Shock Question travislakerat TJ Wrangler Technical Forum 13 11-13-2007 07:18 PM
Shock question Zice TJ Wrangler Technical Forum 22 07-04-2007 05:12 PM
Shock Question yingpin YJ Wrangler Technical Forum 3 04-14-2007 03:39 PM
Help with shock question 90yjjeep YJ Wrangler Technical Forum 3 10-27-2004 08:21 AM
