shock question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > shock question
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 12-06-2010, 09:38 PM   #1
zoomin0074
shock question
I currently have a 3.5" lift and want to put on some OME shocks from a 2.5" kit. If I move my shock mounts higher up on the axle can I use the OME shocks? What if I went SOA?
94 4.0L 3spd. auto
3.5" Black Mountain lift
33x12.5x15 General Grabber MT's 15x8 4" backspacing black mountain wheels.
Red Jeep club #435
zoomin0074 is offline   Reply With Quote
Unread 12-06-2010, 11:12 PM   #2
yoter
If you move the shock mounts yes,if you want to put in the time. You go SOA no.
yoter is offline   Reply With Quote
Unread 12-06-2010, 11:23 PM   #3
gearhead1985
i got done with my soa swap done with waggy springs in the front and i needed a minumum of a 15" travel shocks set up for 5" up travel and 10" down so in short no your shocks wll not work
i want to put a pic here but the computer won't let me so here is the link
[url]http://i641.photobucket.com/albums/u...85/dnsjeep.jpg[/url]
gearhead1985 is offline   Reply With Quote
Unread 12-07-2010, 06:36 AM   #4
Louie4
Injanir
Louie4's Avatar
After I bent some no name front shocks on the front of my jeep I bought some in a pinch from a local 4wd shop in town. I didn't realize for a couple years that my shocks were too short but I was curious why my suspension was limited up front. Anyway I unbolted them and measured. I was 3" short on the front shock so I made some shock tabs out of 1/4" steel plate and cut the stock mounts off. I moved them up so they were centered on the back side of the axle tube and I can still use those shocks.
My advice is to flex the suspension and measure the mounting points. Then measure your shocks and see if it's worth it.
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
