Shock mounting question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Shock mounting question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-11-2015, 04:48 PM   #1
The_Goob
Hell on Wheels
The_Goob's Avatar
One thing that has always bugged me on this yj, why are the shock mounts on axle parallel to axle instead of perpendicular? seems to me the shock should be able to rotate on the bushing instead of flex against it when articulating.
Example
yj, I have seen high flex put alot of stress on these mounts, like trying to bend a finger sideways
This is how I think they should be, maybe im wrong?(realize this isnt a YJ, just the idea)
I need to redo my rear shock mounts, placed them up a little too high. debating whether or not to get different style mount like the second pic above.
Really just looking for some input on the matter from anyone else who has noticed this or swapped their mounts to this style.
The_Goob is online now   Reply With Quote Quick reply to this message
Unread 02-11-2015, 05:04 PM   #2
mickcollinsb16b
Sounds like you are referring to axle wrap or "side load" condition. I don't think it would hurt to mount them that way but as for a side load on the shock- it should be something very marginal that could be compensated in the bushing. Anything further than that would be doing spring damage and possibly frame. Leaf springs don't like to go sideways. SOA conversions with stock YJ packs probably see this most often see this hence the need for the 3link or 4link to prevent axle wrap.
RoknRoll, beer & Jeeps
mickcollinsb16b is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 05:20 PM   #3
The_Goob
Hell on Wheels
The_Goob's Avatar
Maybe I mean the side load you speak of. Excuse this crude drawing but the red circle is the area I mean. I have looked at it under big flex and it looks like something is begging to break. Whether it is or not, seems like mounting the other way would eliminate the stress on the joint.
Never really seen any discussion on here about it, hence the thread.
Unread 02-11-2015, 05:51 PM   #4
jbolty
jbolty's Avatar
The stock lower mounts are a very common thing to break off, and that's probably why.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 06:25 PM   #5
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Only my 2˘, but I think they break because they are cute little crappy brackets that hang too low and get whacked on stuff, or rot off. I also think there is enough flex in the 'bolt through rubber bushing' aspect to not break off after proper sized shock tabs are welded on. Next someone will invent 'revolver shackle mounts' for us to waste money on.
Goob, pop a top shock bolt off, swing the shock down, then try to force it in the direction you think it can't go. I'm confident you will find it can be pushed off-angle plenty to not be a problem with axle flex while in service.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 06:43 PM   #6
cojab
I think it was Tera Flex that already did! I also think they no longer offer them though.
I see what the idea is with them but I believe the rubber grommets allow enough movement to not limit any travel or cause problems.
cojab is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 07:07 PM   #7
Anticanman
RIP one good jeeper
Anticanman's Avatar
I already wasted my money on the revolver mounts. However I haven't had one break off since.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 07:07 PM   #8
ghetdjc320
Some higher-end bilstein's and fox shocks have heim joints at each end. Stock bushings allow for a fair amount of movement but if you decide to run revolvers or orbit-eyes I could see the point of heims in the shocks. Remember the during compression the axle travels toward the shackle a little as well.
-DJC
ghetdjc320 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 07:50 PM   #9
The_Goob
Hell on Wheels
The_Goob's Avatar
Im not "overly" worried that its going to break, it just looks like a stress point and since I might be re-doing my shock mounts I was considering changing the way they sit. Seen plenty done that way, even (some) XJ are that way if I recall.
Unread 02-11-2015, 09:17 PM   #10
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Sorry, I mistyped. I meant 'revolver shock mounts'!
Unread 02-11-2015, 11:24 PM   #11
Anticanman
RIP one good jeeper
Anticanman's Avatar
No, I read it right.
And the problem before
Unread 02-12-2015, 12:33 AM   #12
fratis
fratis's Avatar
I've mentioned this for years. The eyes on the axle end should be mounted perpendicular to the housing.
http://www.polyperformance.com/Syner...us-Shock-Mount
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote Quick reply to this message
Unread 02-12-2015, 04:48 AM   #13
timatoe
Yup
Ruff Stuff has a similar mount too and you get 10% off for being a forum member.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 08:49 PM   #14
IA93Javert
IA93Javert's Avatar
Since I now officially need to know what did you do for your uppers mounts? Looks like Anticanman ran a piece of channel steel across the top. Any other options would be appreciated. I have some welding in front of me and not sure I like the option of putting an oem post back on.
IA93Javert is offline   Reply With Quote Quick reply to this message
Unread 02-18-2015, 10:33 PM   #15
fratis
fratis's Avatar
Ive made a couple sets of hoops but those are now considered a bit old school.
http://www.polyperformance.com/Syner...er-Bracket-Kit
Got a set of these in their longest offering for the front of a YJ. They can be a bit easier to fit then hoops.
