shock lengths - JeepForum.com
post #1 of 3 Old 03-04-2013, 08:08 PM Thread Starter
kjg26
kjg26's Avatar
shock lengths
I have 2.5 OME springs, 5/8 lift shackles, extended front shock hoops up front, and a shock bar in the rear.
I went and took some measures from upper shock mount point to lower shock mount point and from bump stop to frame on a flat surface and ended up with these measurements.
Level Ground
Front
Shock upper to shock lower 25"
bump stop to spring 5"
Rear
Shock upper to shock lower 20.5"
i then flexed my front suspension until the rear tire came off the ground ever so slightly.
Front Compressed (bump stops in contact w/frame)
Shock upper to shock lower 19.5"
Front Extended
Shock upper to shock lower 28.5"
Rear Compressed (bump stops in contact w/frame)
shock upper to shock lower 16.5"
Rear Extended
shock upper to shock lower 21"
i was told it is ideal to "add/subtract 1/2-1" from the measurements so the shocks arent the limiting factor in extensions and aren't acting as the bump stop.
so...
front
extended 28.5 + 1/2 29"
compressed 19.5 -1/2 19"
rear
extended 21 + 1/2 21.5"
compressed 16.5 - 1/2 16"
does all this sound correct?
I need a front shock with extended length of 29" and collapsed length of 19" that has a ride height somewhere around 25"
I need a rear shock with extended length of 21.5" and collapsed length of 16" with a ride height of around 20.5"
I am interested in the "smooth body shocks" made by Fox for BDS. I believe they're called Fox 2.0 performance shocks. I need "loop ends on both ends"
front
98224660 (30/17.3)
rear
98224920 (25.95/15.42)
What yall think?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 3 Old 03-04-2013, 10:38 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Math looks ok to my tired eyes.
Luck Favours The Prepared
Anticanman is offline
post #3 of 3 Old 03-05-2013, 06:38 AM
Rproject
1987 YJ Wrangler
With my OME 2.5" lift I went with Rancho RS5000's here: http://www.jeep4x4center.com/jeep-sh...rangler-yj.htm about half way down the page. I like 'em a lot. Haven't had a problem with them reaching their limits.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
