Shock Help - JeepForum.com
post #1 of 15 Old 04-16-2013, 08:51 AM Thread Starter
cw_myers
Shock Help
I have a 1992 yj that I bought last year and need to replace shocks. It has a lift but I don't know how much of one. If I give you figures can anyone tell me what lift and decent shocks for it.
from ground to bottom of rocker is 22.5"
it has 32" tires on it right now.
Shackels are 4" center to center
I kinda got the front shock measured close to right spots and it was:
extended 31"
compressed 19"
on the front shock I did manage to get N80616 off the shock
on the back I got like(not 100% sure) cs88114
cw_myers is offline
post #2 of 15 Old 04-16-2013, 08:56 AM
jsipe007
Can you also post pictures of your lift?
The N80616 PN sounds familiar... maybe a procomp 2.5 in lift? Can you make out any other letters/numbers on the shocks/spring?
jsipe007 is offline
post #3 of 15 Old 04-16-2013, 09:21 AM Thread Starter
cw_myers
front shocks have:
CO3343j
N8061S
rear shocks have:
CS88114
P8043 B091 045
cw_myers is offline
post #4 of 15 Old 04-16-2013, 09:23 AM Thread Starter
cw_myers
hope this info helps
cw_myers is offline
post #5 of 15 Old 04-16-2013, 09:44 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Take the shocks off. Disconnect the sway bar. Flex it out completely and measure for extended and collapsed lengths. Its the only way to do it.
Luck Favours The Prepared
Anticanman is offline
post #6 of 15 Old 04-16-2013, 10:35 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Originally Posted by cw_myers View Post
front shocks have:
CO3343j
N8061S
rear shocks have:
CS88114
P8043 B091 045
CW,
As Anticanman said, take the shocks off and disconnect the sway bar. Then flex the Jeep out and take measurements of extended and collapsed length at all 4 corners.
Then give one of our Jeep Experts a call at 800-988-4605 and they can hook you up with the shocks you'll need for your rig.
Feel free to shoot me a PM if you have any questions. I'll be more than happy to help.
-Zach
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #7 of 15 Old 04-16-2013, 11:51 AM Thread Starter
cw_myers
Originally Posted by ExtremeTerrain View Post
CW,
-Zach
okay did the front if I did it right i hope....21" and 24"
cw_myers is offline
post #8 of 15 Old 04-16-2013, 12:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Are your shocks disconnected? You want to measure the mounts, not the current shocks. It sounds trite but trust me, its the way to do it.
post #9 of 15 Old 04-16-2013, 12:53 PM Thread Starter
cw_myers
I disconnected the bottoms...top nut will not come off on the front. I measured as close to center of the mounts as possible.
cw_myers is offline
post #10 of 15 Old 04-16-2013, 01:03 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Yea, you'll want to completely remove the shocks and flex the Jeep. Then measure mount to mount. Also make sure you're flexing it to full bump. That way when you get the shocks, you'll have the full range of flex and they won't be limiting you.
Let me know if you have any questions!
-Zach
Jake R. |
Off-Road Outfitters
XTJake is offline
post #11 of 15 Old 04-16-2013, 03:06 PM
jsipe007
removing the top nuts can be a pain but if your shocks are toast, use a pair of vice-grips to hold the flange that is under the upper shock mount.
jsipe007 is offline
post #12 of 15 Old 04-16-2013, 08:53 PM
Ethyl
im kinda doing the same thing I actually coming close to finding what I need but ill be replacing my rear leafs with procomps , my front shocks at Monroe load adjusted coil overs and they work great I love them , so im going to do the rear with the same set. the problem is if I fully flex out , its 22" , that might change when I get the procomps right ? they are thicker . also my shock mounts are gone I removed my sway bar and took the lower mounts from that and moved them to the rear to make new shock mounts just below the springs. Im thinking I should get 25" shocks to compensate for new spring later , right ?
Ethyl is offline
post #13 of 15 Old 04-17-2013, 07:22 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Ethyl,
The best thing to do is to wait until you get the new springs. You won't know your exact measurements until the new springs are sitting on the Jeep.
Even if you know the lift height the springs will give, your Jeep will differ from someone else's Jeep. Once you get the new springs on, then go flex the Jeep and take new measurements.
Shoot me a PM if you have any other questions. I'll be happy to help.
-Zach
Jake R. |
Off-Road Outfitters
XTJake is offline
post #14 of 15 Old 04-17-2013, 07:41 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Ethyl,
-Zach
Finally, a vendor that gets it.
post #15 of 15 Old 04-17-2013, 01:47 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Anticanamn,
Thank you! We definitely would rather make you guys happy and have your Jeep's built right, the first time. Feel free to shoot me a PM if you have any questions, and I'll gladly give you a hand.
-Zach
Jake R. |
Off-Road Outfitters
XTJake is offline
lift , shocks , YJ
