Shock & Diff. Upgrade Question - JeepForum.com
post #1 of 2 Old 03-01-2002, 02:39 AM Thread Starter
KPOM
Planning on swapping my four banger motor out for something more powerful. Undecided which motor yet, either a Ford 302 or a Chevy 350, but I was just wondering in either case, what would the best shock upgrade be? Something that can withstand the type abuse of a heavier motor with semi-decent pavement performance (i.e. - I don't want to hit my head on my roll bar when I go over a bump).
Also, does anyone have any suggestions for front/rear differentials? Usage would be for light offroading once or twice a month, but mostly daily driving. The idea here is that I'm definately going for more acceleration, so I would assume something very powerful for the front (when 4WD is enabled) and something with a bit more pep off the line for the rear (or street RWD use)..does this make sense?
Thanks in advance.
"...that's why my car is protected by Smith & Wesson. No insurance companies, no cops, just a .45 to the side of the head."
KPOM is offline
post #2 of 2 Old 03-01-2002, 07:37 AM
RodeoRob
RodeoRob's Avatar
Need more info... what size tires do you wanna run? The stock axles would have no problem holding up behind a 302 or 350 with the stock tires. Of course, if you're planning on dumping the clutch at 5k RPMS on the drag strip, yea, you could break em with the stock tires... but i'm talking about normal driving w/ mild offroad.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
Shock upgrade mysideup Wrangler General Discussion 0 03-31-2009 05:46 PM
RC shock upgrade needed? modfox YJ Wrangler Technical Forum 5 02-02-2009 03:34 PM
shock upgrade bigV TJ Wrangler Technical Forum 5 11-14-2006 11:44 AM
shock upgrade AJKs-tj TJ Wrangler Technical Forum 1 03-05-2005 06:47 PM
Stabalizer shock upgrade? franco802 TJ Wrangler Technical Forum 6 11-03-2003 05:19 AM
