Shifting Problem - JeepForum.com
post #1 of 2 Old 06-25-2001, 11:12 PM Thread Starter
shea324@aol.com
Shifting Problem
I have a mostly stock 90 YJ with an AX-5 transmission. Ever since I've had it the transmission has made this slight grinding sound when in certain conditions. Normally it shifts fine, which is why I didn't address this earlier. But when downshifting at high speeds (relative to that gear) or when I try to upshift fast at high RPM's, I get a little grinding sound and sometimes I have to force it to go into that gear. Does anyone have any idea what this could be? Has anyone ever had a similar problem? I would apreciate some help here. Thanks.
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #2 of 2 Old 06-25-2001, 11:29 PM
jpwranglr9
it probably is the syncro gears (and maybe sleaves) in the trany. i had this problem in mine and left it for a while too. then one day the third gear syncro gear got jamed. you can rebuild this yourself or have someone do it. it's not a cheap job though. i did it myself and cost me 200 or so just for parts. but i am pritty sure thats the problem. good luck
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
shifting problem need help flopp TJ Wrangler Technical Forum 13 02-10-2009 08:55 PM
shifting ecm problem Help leeandjen TJ Wrangler Technical Forum 2 11-30-2007 08:45 AM
Shifting different when cold or warm -final attempt at shifting problem. IAJack TJ Wrangler Technical Forum 12 01-20-2005 09:51 PM
A Little Different Shifting Problem Kevbo6204 YJ Wrangler Technical Forum 9 05-10-2004 07:58 PM
Shifting Problem RubiconTJ TJ Wrangler Technical Forum 3 11-17-2002 06:41 PM
