shifting??? - JeepForum.com
post #1 of 5 Old 11-11-2001, 01:56 PM Thread Starter
Atropine
Atropine's Avatar
shifting???
Im having problems shifting into 2nd and 4the gears, I know it has to do with the dropped transfer case and I think its hitting my tuffy console. Any insight??
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #2 of 5 Old 11-11-2001, 02:06 PM
Big92Jeep
You may have to trim the hole in your floorboard. Your shifter is probably hitting the tub. I had to cut mine back about an inch to get 2nd and 4th after 3"lift.
~Rick
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #3 of 5 Old 11-12-2001, 03:34 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
When I did my 4" lift, I had to cut out my floor pan, and move the black plate, shift boots and everything back a little way. My stock console is almost in the way for me to use my reverse ..
Are you having problems with your reverse?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 5 Old 11-12-2001, 03:55 PM
Big92Jeep
Like I said I cut mine back about an inch. After that no problems.
~Rick
post #5 of 5 Old 11-13-2001, 05:43 AM Thread Starter
Atropine
Atropine's Avatar
I pulled the innner boot off and moved it back 1 inch, moved the outer boot back and moved the tuffy back 1 inch. Problem solved! Thanks fellas!
93' YJ
00' TJ
02' KJ
04' Dodge Ram
Atropine is offline
Shifting out of 4 lo bigfish10 Wrangler General Discussion 14 05-04-2009 02:11 PM
Shifting from 1st to 2nd bunkrdfool JK Wrangler Technical Forum 6 01-17-2009 12:13 AM
Shifting to 4lo method84 TJ Wrangler Technical Forum 15 01-15-2006 01:13 PM
shifting into 4 hi after MML and BL kevinofcamelot TJ Wrangler Technical Forum 4 09-03-2005 08:02 AM
Shifting different when cold or warm -final attempt at shifting problem. IAJack TJ Wrangler Technical Forum 12 01-20-2005 08:51 PM
