Shifting - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Shifting
Free shipping on slip yoke eliminator kits New lower PriceNew! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 03-18-2015, 07:13 AM   #1
Rafthegiraffe
Shifting
When I'm reversing or in first gear about to move, it becomes incredibly hard to move out into neutral. But shifts gears smooth after 1st. I had a problem with the slave cylinder previously and I had replaced it. I pumped the clutch until all the bubbles of air was out. It was alright for a little while after but now I'm confused at what the problem is.
Rafthegiraffe is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 12:11 PM   #2
bck4more
1987 YJ Wrangler
Welcome to the forum.
1987 4.2 automatic,33"Pro Comp Mud,2100 motorcraft,nutter bypass,SOA,SYE,Tom Woods driveshaft
bck4more is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 08:53 PM   #3
mickcollinsb16b
mickcollinsb16b's Avatar
Welcome to the forum. Maybe the clutch master needs replacement as well. Mighty-Vac's are really helpful for a good extraction of air from a hydraulic system.
RoknRoll, beer & Jeeps
mickcollinsb16b is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 09:15 PM   #4
Rafthegiraffe
Thanks I'll try that tomorrow. And see if I can get all the air out.
Unread 03-18-2015, 09:58 PM   #5
mickcollinsb16b
You can get a generic MightyVac for cheap at HarborFreight
Unread 03-23-2015, 10:41 AM   #6
Rafthegiraffe
So the clutch got really bad again today. I had to pump the pedal to get in gear. I took off the master cylinder cap to see if there were bubbles but nothing came up. The fluid looked murky though. Is there another way to bleed the system?
