Shifter stick hardware question - JeepForum.com
post #1 of 8 Old 04-03-2013, 10:26 AM Thread Starter
atldude
Last nite I was screwing around wit the vac disco and testing things out seems like still works but I think I yanked the 4wd shifter a little harder couple of times before I greased things up underneath and the dang stick popped out lol and the dang clip broke
So I found these two searching around.
http://www.quadratec.com/products/52112_0200.htm
http://www.quadratec.com/products/52112_0201.htm
Does anyone know if both shifters (gear and 4wd) use the same parts? I can't tell if this is only for the gear shifter or not. I know that the clip I took out looks identical (may be size is diff) but did not see any spacer come out
I don't want to tear down the gear shifter cause I am sure I will tear it up trying
atldude is offline
post #2 of 8 Old 04-03-2013, 06:24 PM Thread Starter
atldude
Anyone?
atldude is offline
post #3 of 8 Old 04-03-2013, 06:31 PM
flea1987
well if you have a spare gear piece handy could always compare the hole sizes
flea1987 is offline
post #4 of 8 Old 04-03-2013, 08:00 PM Thread Starter
atldude
Thanks man
I guess i was trying not to screw with it. Unfortunately don't have a spear.
atldude is offline
post #5 of 8 Old 04-03-2013, 08:36 PM
flea1987
might be able to see if you remove the cover, or find a picture with it removed
flea1987 is offline
post #6 of 8 Old 04-03-2013, 09:21 PM
jerresredyj
Those parts will work on your TC shifter, I just replaced mine. I can't say for your trany shifter.
jerresredyj is offline
post #7 of 8 Old 04-03-2013, 09:34 PM
jbolty
jbolty's Avatar
I had the same problem
http://www.jeepforum.com/forum/f12/t...-fixed-585098/
jbolty is offline
post #8 of 8 Old 04-04-2013, 10:08 AM Thread Starter
atldude
Thanks guys went ahead and ordered them. That trick with the nuts looks great but i dont have a welder ..yet
atldude is offline
