Shift tower problem - JeepForum.com
post #1 of 3 Old 07-21-2005, 10:06 AM Thread Starter
YJfrom94
Shift tower problem
Just as I thought my first clutch replacemnt was finally going well, I just ran into a big problem. I got the transmission back in place and got everything hooked when I went to get the shift lever back in. Problem is, I can not get the retainer down into the shift tower, there is no way it will fit. So I took the shift boot thing off and look in from the top and I see the problem. There is a flat spot on the hole where the shifter goes. It looks as though the trans rolled onto its side. It's been in the garage for a few weeks, so I guess it's possible. Whatever the case, I can't hook up my shifter. Now, I was thinking about trying to to hammer the flat spot a little and get the retainer to fit. Will this work? or will it cause me more headaches? If there is no other way, does anybody know where I can get a shift tower and how difficult that would be to replace?
94 YJ 4.0 HO/AX-15
3.5" BDS lift, 33" BFG Mud terrains
So much more to do, so little money.
YJfrom94 is offline
post #2 of 3 Old 07-21-2005, 10:52 AM
TellyDSP
Poland and PPV!!!!
The shift tower is easy to replace. 4 bolts and a $1.50 gasket. I would be careful hammering it out as I believe its aluminum. If you can find a mold to put in and hit that, you might be good. There are also those two nipples that the retainer hooks to that you have to make sure you dont destroy while hammering. If you go to a pick and pull, you should be able to find one. I'm headin to one this weekend that has a lot of manual 4.0 cherokees. If anyone knows if they are the same I can try to grab you one.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 3 Old 07-21-2005, 12:43 PM Thread Starter
YJfrom94
Thanks for the help. I lightly tapped it once with a small hammer and it bent outward enough that the retainer fit no problem. It isn't lined up perfect but it's pretty good, plus the dust boot covers it up fine. If any problems occur I will replace it right away, but for now I'll just leave it like it is. Thanks for the offer though.
94 YJ 4.0 HO/AX-15
YJfrom94 is offline
AX15 shift tower bushing Opihi59 YJ Wrangler Technical Forum 27 01-15-2016 11:13 AM
AX15 shift tower bushing Opihi59 YJ Wrangler Technical Forum 20 08-17-2012 01:20 AM
AEV rear track bar tower problem s1edneck700 JK Wrangler Technical Forum 14 12-10-2009 09:02 AM
Filling AX-5 through shift tower? superslayer TJ Wrangler Technical Forum 1 02-21-2009 10:09 AM
HELP!!! Shift Tower Trouble topfuel83 TJ Wrangler Technical Forum 2 05-07-2005 07:41 PM
