Hey guys I decided to check on my transmission and possibly do a fluid change. However I noticed a gasket or something that once resembled rubber in the shift tower. It was all cracked and broken apart and only accounted for about 1/3 around the hole. However some of the gasket/rubber fell into the trans. Should I worry about this? Also do I need to or should I get another rubber gasket for the tower?
The red outline is where the remaining "rubber" was.
BTW its an AX-15 in my 92 YJ.
